keeping a black bike looking good
[IMG]local://upfiles/49439/86566B8E29EC4FA99D17337D63D9E837.jpg[/IMG]
Some products hide scratches by filling them in. These products are only temporary fixes. The other type of product contains micro-abrasives which actually remove the scratches. The longer the product is worked in, the more these micro-abrasives break down. They are activated by heat and friction. They are not a wipe on - wipe off deal. If not being used with a buffer, they require LOTS of elbow grease.
I use Meguires paint cleaner to remove old wax as a first step. i then use Meguiars polish. This is one of the products with the mentioned micro-abrasives. My third step involves using 3M Perfect-it 3000 Ultrafina, also contains micro-abrasives, but finer than the polish.
http://shows.implex.tv/3MTV/Root/AAD...=1206020746593
The final step I use is Meguiars NXT wax, These products work great for routine maintenance.I use microfiber pads, a different clean pad for the application of each product, then a different clean microfiber towel for the removal of each product.
For deeper scratches, I use Meguiars Scratch-X and have achieve great results. After the Scratch-X, I go through the routine using the polish, then Ultrafina, then wax.
Each of the Meguiars products is readily available through auto parts chain stores. I had to go to an automotive paint supply business to purchase the 3M Ultrafina. It is not cheap, arounf $40.00 a quart.
Rookie Disclaimer: I am by no means a detailer, but have found this is what works for me.
