Turn signal plug?
Old Mar 20, 2008 | 10:51 AM
buzzardgame's Avatar
buzzardgame
Default Turn signal plug?
I am trying to remove the wires from the connector any tricks? I Have flipped the back part were the wire comes in up,but cannot get the pins to come out.Hd make a tool for the removal of these but im trying to avoid buying that.Any input would be appreciated.
Old Mar 20, 2008 | 10:56 AM
Muddyape's Avatar
Muddyape
Default RE: Turn signal plug?
Paper clip......push it in from the front (opposite end of wires) and up. Theres a tab that engages the plastic.....not alot of pressure needed. take your time and dont force anything. I use a piece of sand paper and sanded a little bevel on the end of the paperclip. Kinda of like a little wedge. Oh yeah, push the wire forward a little and then push the paperclip in, then pull wire out. Confusing I know but it is possible.
Old Mar 20, 2008 | 11:03 AM
buzzardgame
Cool thanks for the tip,I will give that a shot.I worked on that thing for an hour with a safety pin couldnt get it. Irritating as hell
Old Mar 20, 2008 | 12:31 PM
mud's Avatar
mud
ORIGINAL: buzzardgame
amp connectors
Have a look here.
this link should take you to page 11 of UNDER 50.
posting # 403
https://www.hdforums.com/forum/dyna-...ml#post2700467
mud
Old Mar 20, 2008 | 04:18 PM
BlueShift's Avatar
BlueShift
I used a long rather large guage sewing needle. I could feel the tip of the needleengage in the clip and the wire popped right out , no problems.
I tried a paper clip first but couldn't get it under the plastic clip.
Good luck.
Old Mar 20, 2008 | 04:46 PM
Lone Watie's Avatar
Lone Watie
thanks for that great link Mud - been wondering what those little bastards look like inside. Do you have any tips on crimping without the $200 tool on molex/deutsch/amp connectors. Looking to do some headlight wiring soon and want to use OEM connectors but don't want to spend $$$$ on a specialty crimper. Thanks.
Watie
++ on the paper clip for molex. Amp connectors I used a dental pick, but picks diameter too big for the molex so used the paper clip method. I think some stiff mechanics/safety wire will work well too.
Old Mar 20, 2008 | 05:24 PM
baxter's Avatar
baxter
i used the tip of a small pointed blade. less then a minute i had em all out.
Old Mar 20, 2008 | 05:43 PM
mud's Avatar
mud
ORIGINAL: lonewatie
Watie
Watie, Yeah, I built a crimping tool for those tiny little fittings
a couple weeks ago when I replaced my bars.
I took a bunch of pictures of the crimp tool,
as well as a similar explain on the Deutsch connectors.
The Molex
https://www.hdforums.com/forum/4230311-post40.html
the Deutsch
https://www.hdforums.com/forum/dyna-...ml#post3061604
Don't let me forget to put the crimp tool in the Under 50,
I haven't had time, but I do need to find some.
mud
Old Mar 20, 2008 | 07:43 PM
Lone Watie's Avatar
Lone Watie
Mud - I'll post a reminder in the under 50 thread - and pm you in a couple days. I know how it is being busy. Thanks - watie.
Old Mar 21, 2008 | 08:34 AM
buzzardgame
Mudpuddle thanks for the link that really helped alot.
trip20
Feb 4, 2020 02:55 AM
RiderHD
Mar 19, 2019 10:19 AM
ZeroFiveFour
Oct 28, 2010 07:52 PM
yoseppi
Aug 20, 2008 09:48 PM
fishawk
Jan 13, 2007 12:23 AM
