Lets take a Brake!
Old Mar 26, 2008 | 08:57 AM
DeJavu's Avatar
DeJavu
Default RE: Lets take a Brake!
ORIGINAL: Humanoid
I use both because I know that needs to be my natural motor skill. If a sudden emegency happens I want my body to react and use BOTH brakes. There will be no time to think about it.
Couldn't agree more, after years riding a Cafe' bike I had developed the ability to stop w/both brakes and also to brake while turning(braking to the apex). Served me well in a recent accident, was able to almost avoid a collision with a left turn/didn't see you cager. Totally on reaction, I made a knee draggin' left of my own while braking hard, both brakes. Didn't lay it down, but still clipped the rear of the car with my leg. Definetely no time to go straight and stop or even slow much, would have been a 40+mph Tbone. My Evo chopper handled it very well, but might have avoided the hit if I was on the old RD400 Yammy!
My wasted years emulating Kenny Roberts(I'm an old fart)weren't so wasted after all!
[IMG]local://upfiles/36103/9D75C41FACE2453A88DE5DCE7442CA71.jpg[/IMG]
Old Mar 26, 2008 | 09:39 AM
07bobber's Avatar
07bobber
ORIGINAL: BRRider
Most of the time both. But the hand brake usually first then the foot.
+1
Old Mar 26, 2008 | 11:08 AM
hk_shooter's Avatar
hk_shooter
ORIGINAL: BLade1127
I was always taught to be at 70% front, 30% rear, but I tend to use the front only, unless I need to stop in a hurry.
Pretty much sums it up for me, too.
Unless it's on a low traction surface gravel, sand, etc.
Old Mar 26, 2008 | 11:23 AM
fiend138's Avatar
fiend138
I firmly believe it is a good idea to use both brakes as a good habit more than anything. If your standard is to brake properly or in other words most efficiently, in a tight spot your reaction would be more like to do the same. Not grab a hand full or a foot full and high or low side.
Old Mar 26, 2008 | 12:52 PM
xmarine's Avatar
xmarine
ORIGINAL: 07bobber
ORIGINAL: BRRider
+1
+2
Old Mar 26, 2008 | 03:34 PM
alabori's Avatar
alabori
I am fresh off a supersport so had forgotten there was a rear break. Since I've started leading with the front then the back I haven't had any serious pucker moments.
Old Mar 26, 2008 | 03:46 PM
ezriderpgh's Avatar
ezriderpgh
Normal speeds, both with rear applied first. In heavy traffic, front. Downhill turns, rear. Loose surface, rear. Put myself down 1 time in 32 years, gravel on a bend, no brake involved.
[IMG]local://upfiles/52705/67A2953C21C944B2B2CC1265027CAC87.jpg[/IMG]
Old Mar 26, 2008 | 03:57 PM
paisleysdaddy's Avatar
paisleysdaddy
I was always a front brake only user when I had sport bikes. Then I took a rider safety course and they emphasized the quicker stopping times while using both brakes. Since then, I use both. I have to agree that certain situations cause my intuition to put me one way or the other.
Last summer, I had a car in front of me signal and ready to turn left. As I went to go around on the right, they changed their mind and went right as I was right there. My quick reaction was both brakes. I literally stopped on a dime and the rear end only fished off a couple inches just before I was able to throw my feet down. I didn't even so much as lay the bike down, even with my passenger on the back.
Old Mar 26, 2008 | 04:18 PM
jhmp's Avatar
jhmp
Almost always both. If I'm all ready slow, it might be one or the other. When it's both I slightlylead with the rear. I think the grade, speed, and angle of attack have to be considered each time.
Old Mar 26, 2008 | 05:24 PM
Splatter's Avatar
Splatter
Both if I'm coming down from road speed to walking speed. At that point it depends on my intention. If my intention is to stop, then I'll grab more front brake. If my intention is to keep going (slowly) I'll get off the front brake and ride the rear while I feather the clutch.
