derby cover
Old Mar 27, 2008 | 06:19 AM
durwood's Avatar
durwood
Default derby cover
when changing my derby cover on my 2006 dyna wide a little bit of fluid ran out maybe 3 or 4 table spoons should i be conerned,, what isit trans fluid??
thanks for your advice
Old Mar 27, 2008 | 06:22 AM
dyna07custom's Avatar
dyna07custom
Default RE: derby cover
What fluids are you running if you went to synthetic its the same as engine and trans oil. Was the bike level when you changed cover? If not hold bike level (with lift or help) remove cover and replace the fluid
Old Mar 27, 2008 | 08:17 AM
bikerdog134's Avatar
bikerdog134
you can just put a piece of wood under the kickstand to level it
Old Mar 27, 2008 | 08:41 AM
BLade1127's Avatar
BLade1127
It shouldn't hurt if too much. When will you be changing the fluids again? Next time, put a 2x4 under the kickstand to level it up just a bit.
kelton3
Jul 15, 2018 03:58 PM
gweissel
Mar 7, 2017 01:28 PM
brummet24
Oct 16, 2012 09:35 AM
studiopeg
Jul 28, 2011 06:33 PM
YellowHawk
Dec 28, 2007 01:33 PM
