ISO Grips - Slippy??
I've just added a set of Kuryakin ISO grips to my WG!
Anyways, yesterday I thought I'd give the grips a road test
They seemed to virtually remove the usual vibes - so much so, that I didn't get the dreaded hand numbness at all!!
Then..................it started to rain, well pi** down really, and my hands kept sliding off the grips!
In the end, I was gripping so tight, it caused a pain across the top of my wrist.
Maybe it's because I have Buckhorn bars (hands facing downwards etc.)??
I know alot on here have these grips and are happy with them (so am I from a vibe and comfort point of veiw) but wondered if anybody has had the same issues?
I'm just on th edge of ordring the footpegs to match, but if these are as slippy, I'm not so sure
I've put my apes back on today, not just because of the grips! I've had the buckhorns on for two years now and I've been looking at the forum recently and damn the apes look good on a WG's
so maybe it will also cure the sliding off stuff??Any help or advice would be welcome - before I order the pegs
Thanks,
Ian.
[IMG]local://upfiles/33561/6510096881004096A5D43E32064B52CA.jpg[/IMG]
the grips will get better as they get older (see also: more sap, ect build up). I had the same problem when I first got mine. as for the pegs... they are still slick in the rain after six months. I am considering changing them for this reason. Also another item to look out for- the left grip has a tendency to slip off at high speeds (at least mine anyways)
Good luck.
I'm finally putting the grips on today....if I can muster the courage to slide the left one on in one smooth move. Replacing the throttle grip was no problem at all.
