Dumb (n00b) question - BS1 vs BS2
Old Apr 10, 2008 | 06:14 PM
rhinoWErX's Avatar
rhinoWErX
Default Dumb (n00b) question - BS1 vs BS2
Tried to figure it out but couldn't. Can anyone tell me, what is the difference between the Arlen Ness Big Sucker Stage 1 and the AN BS Stage 2?
Looking at the site, they look pretty similar to me.
Why would you use one over the other?
Cheers,
-Jack
Old Apr 10, 2008 | 06:22 PM
LeadSlinger0311's Avatar
LeadSlinger0311
Default RE: Dumb (n00b) question - BS1 vs BS2
you only need to bs 2 if you are doing engine upgrades .
i belive it has a higher air flow .
if you are just doing pipes and fuel mangement or carp stage one you only need the BS stage 1
hope that helps
slinger
Old Apr 10, 2008 | 06:24 PM
wkdavistx's Avatar
wkdavistx
ORIGINAL: rhinoWErX
Cheers,
-Jack
This is from the link you sent, but I'm glad you did because I didn't know until reading it. 20% larger air filter sounds good for my 95" high compression build.
[*]Stage I Kit features a Team Ness High-Flow filter that accepts all 1993-up oval or round OEM outer covers.[*]Stage II Kit features a 20% larger Team Ness High-Flow filter that requires an 8" round Ness or OEM outer cover.
Old Apr 10, 2008 | 06:25 PM
sniper77's Avatar
sniper77
I was going to say the 2 is actually larger but I see you found out yourself.
Sethc1020
May 13, 2019 08:12 AM
ravsta
Oct 28, 2014 10:24 AM
Papi
Exhaust System Topics
Jan 31, 2011 08:48 PM
Herr Monk
Nov 19, 2007 08:18 AM
Todd Vikan
Aug 12, 2006 04:20 PM
