standard or hd progressive
Old Apr 19, 2008 | 03:13 PM
SM49's Avatar
SM49
Default standard or hd progressive
Is there much difference between standard & hd progressive shocks,I put on 11 1/2 standards on my 2001 FXDP,fine for me,160lb but bottoms on belt guard & on tire when 2 up combined weight of 350.
Old Apr 19, 2008 | 05:13 PM
Chipstah's Avatar
Chipstah
Default RE: standard or hd progressive
Your standards are adjustable so you ought to be able to crank up the preload - Progressive supplies the wrench in the box when you buy their shocks.
To answer your question, I expect there is a big, noticeable difference though never having had the standards I'm not able to quantify it. The HDs are very FIRM - you feel every bump and can get airborne if not careful on potholes - LOL! But boy is the handling something else - they really hug the twisties. I love 'em and I'm 185 lbs which is well below Progressive's suggested weight for HDs.
Old Apr 19, 2008 | 06:01 PM
SM49's Avatar
SM49
I have them set full stiff for 2 up riding.
Old Apr 19, 2008 | 09:48 PM
Chipstah's Avatar
Chipstah
Well, I'd say you're pushing the limits quite a bit then since Progressive recommends the HDs for two-up and anything over 240 lbs. I never ride two-up it seems, but got the 11" HDs just in case I ever choose to, and for the firmer/lower ride w/o having any clearance issues - didn't want to have to buy 'em twice if ya get my meaning. But looks like maybe you should, unfortunately. Probably a good market here on the forum if you decide to sell your standard duties so shouldn't hurt ya too bad.
Old Apr 19, 2008 | 09:57 PM
Kuniskis's Avatar
Kuniskis
I ride two-up all the time (combined weight= 300lbs) and haven't had any problems with the standard duties. They are 11" and I crank up the pre-poad when two-up.
Old Apr 20, 2008 | 05:21 PM
SM49's Avatar
SM49
I checked the specs for this part number,they are actually for an FXR ,and apparently for some reason they havelighter springs than for other dynas.
gadgetguy1288
Jun 29, 2014 01:13 PM
dyna bomb
Nov 19, 2012 06:43 AM
07JakeelwoodHD
Mar 26, 2012 11:45 AM
TangoDown
Jul 3, 2011 05:03 PM
MR. SCOOTINN
Jun 5, 2007 02:29 PM
