Primary Plug Leaks
Old Apr 24, 2008 | 09:44 PM
skip3406's Avatar
skip3406
Default Primary Plug Leaks
I have forward controls and the cheap plug they use to fill the hole in the primay leaks.
Anyone else have problems with this plug leaking and how did you cure it.
[IMG]local://upfiles/29615/94CA9D009AE147C1ABEBC2962208AE91.jpg[/IMG]
Old Apr 24, 2008 | 09:48 PM
DougsDyna's Avatar
DougsDyna
Default RE: Primary Plug Leaks
Never had a problem in 3 years.
DougJ
Old Apr 24, 2008 | 09:59 PM
skip3406's Avatar
skip3406
ORIGINAL: DougsDyna
DougJ
Doug, that 3 times longer then mine.
Old Apr 24, 2008 | 11:58 PM
mud's Avatar
mud
ORIGINAL: skip3406
skip, the only way you will have a leak there is -
if this gasket is forked up. (red arrow below, part# 63869-06)
Has nothing to do with what you call"the cheapplug".
mud
Old Apr 25, 2008 | 09:47 AM
tbone52's Avatar
tbone52
Mud nailed it.
I had that little gasket changed under warranty afew of months ago. The original from the factory had slipped down a little upon installation of the outer primary cover and pinched it just enough for it to eventually fail. They showed me the old gasket and it had the impression of the gasket surface of the outer primary cover and where the shifter rod had folded the gasket over into the tower that it passes through. A new gasket and no leaks from the shifter any more.
Old Apr 25, 2008 | 10:49 AM
skip3406's Avatar
skip3406
ORIGINAL: mudpuddle
ORIGINAL: skip3406
mud
Thanks mud.
I knew there was more to it then just a little loctite on the chrome plug.
Old Apr 25, 2008 | 11:02 AM
skip3406's Avatar
skip3406
ORIGINAL: tbone52
Mud nailed it.
Thanks tbone, that may be what happened to mine also but my local dealer won't cover it because I didn't buy the bike from them and it is and after marketpart that wasinstalled buyanother dealer. They might fix it but I figure it will cost me more to trailer it there then the parts cost. At least when I bought it last year it was $2000 less then my local dealer and the forward controls were free.
Old Apr 25, 2008 | 08:42 PM
skip3406's Avatar
skip3406
It was the $.95 tower gasket leaking. Too bad the primary gasket cost $30.40 & another $7.50 for the derby cover gasket just to fix it. I guess if you want it done right you have to do it yourself.
[IMG]local://upfiles/29615/18249443E97C4768B4273C038D4C4C0D.jpg[/IMG]
Old Apr 25, 2008 | 09:19 PM
mud's Avatar
mud
Way to go skip. Take the bull by the horns.
I have one of the 30 dollar gaskets hanging on the wall,
ready to go.
I reused the original, and kept an eye open for drips
or seepage. No problems after a year and a half or so.
mud
ORIGINAL: skip3406
Old Apr 25, 2008 | 09:20 PM
ezriderpgh's Avatar
ezriderpgh
ORIGINAL: mudpuddle
ORIGINAL: skip3406
mud
+1 Happened to me after the dealer installed forward controls, took it back and they replaced the gasket and made me happy.
Montanadyna
May 26, 2017 11:08 AM
fatkidfrank
Oil Archive (no new posts)
Aug 9, 2012 03:05 PM
stbobshadow
Jun 27, 2012 01:45 PM
JRK5892
May 5, 2009 04:58 PM
skullandcircle
Aug 5, 2007 03:31 AM
