I sprung a leak (primary)
Old May 5, 2009 | 03:07 PM
JRK5892's Avatar
JRK5892
Default I sprung a leak (primary)
hey guys... i just swapped out my fluids and noticed a bit of run off on the plug deal i got wth my forward controls... I did not think much of it... wiped it off... and this morning noticed it is back... so it looks like i need to replace it... However, it has been a few years since i did my forward controls... any ideas with something i can plug this sucker up with? i can not remember what the plug even was?!
Old May 5, 2009 | 03:15 PM
TAB1784's Avatar
TAB1784
Maybe get an (or replace the) O-ring to go around the plug you've got in the hole ....
I changed my engine oil, filter, transmission fluid and primary fluid last week; and, at first was getting two really slow leaks developing just aft of the drain plug and just below the inspection cover where I had cut off the mid-control shift lever. I stuffed a rubber stopper in the end of the tube and replaced the primary gasket, tower gaskets (mine has two),the inspection cover gasket, and the O-ring for the drain plug, and refilled it with oil ... it's been three days and it's dry ... so, I think that fixed my issue ....
Todd
Old May 5, 2009 | 03:18 PM
JRK5892's Avatar
JRK5892
that a boy! thanks bud! i may have to get my brother over so i can lean the hell out of my bike so i dont loose any more of the fluids!
Old May 5, 2009 | 03:20 PM
TAB1784's Avatar
TAB1784
Or you could try that trick that Mudpuddle does where he lays his bike over on a 4x4!
... 'cept I think you're talking about laying over on the other side ....
Old May 5, 2009 | 03:23 PM
lhcstreetbob's Avatar
lhcstreetbob
hey what kind of fluids did you change to i was thinking about the amsoil? sorry i cant help with the plug
Old May 5, 2009 | 03:24 PM
Richinlc's Avatar
Richinlc
ever heard of that thing called lean right??? dont know how far it would lean it but saw an add once and it looked like a cool tool
Old May 5, 2009 | 03:41 PM
redrubicon2004's Avatar
redrubicon2004
If you only have one qt of fluid or less in the primary, you should be able to take that cover off without losing any fluid if the bike is standing upright. Throw it on your motorcycle jack and it should be fine. It is an inspection cover
Old May 5, 2009 | 03:53 PM
TAB1784's Avatar
TAB1784
Red:
'06 don't have the inspection cover ...
Kit:
I switched to Royal Purple synthetic oil in the engine this time (at 15,000) ... had been using dino before.
Went with H-D Formula in the transmission and primary case ... I'm pretty sure it's dino, as well ....
Todd
Old May 5, 2009 | 04:04 PM
chad peterson's Avatar
chad peterson
If you're talkin about the plug or cap where your mid shifter used to come out of the primary it's the little round gasket (sticky on one side) inbetween the inner & outer primary...if that's the one you mean? Real easy fix!
Old May 5, 2009 | 04:15 PM
midnitewolf's Avatar
midnitewolf
Don't mean to hijack the thread
with the bike standing upright and the derby
cover off where should the fluid level be ?
