Tire change question...
Old Apr 26, 2008 | 07:07 PM
TurkeyRun's Avatar
TurkeyRun
Default Tire change question...
Dyna Brethren:
I just got done doing my first ever Harley tire change. I replaced the stock rear with another Dunlop at about 8K, standard stuff from what I gather reading around here. Anyway, to the question. Getting the tire off the rim was a friggin' b*tch. Fortunately, a buddy stopped by and between the two of us and a couple tire irons we got the darn thing off. It almost seemed that there was some kind of glue on the bead. After we got it off, he left and I got my new one mounted using an old trick from my dirt-bike days; soapy water. New tire practically jumped on all by itself (well, except for the last 12 inches or so of the back side..)
All aligned belt tension checked, showered an back in the house, I get to second guessing myself. Is it possible that there was some bead sealant/glue/stuff on the bead of the original factory tire? Am I screwed for not putting some of this mystery goop on when I put on the replacement tire? After all, this isn't my 250 Elsinore.... Am I inviting trouble by just trusting the soapy water will disipate and there will be a "stong enough" seal on the bead with the friction between the rubber and the rim? Will getting this replacement tire off be just as hard or is this just like cracking that beige lock-tite they use at the factory?
Any advise is appreciated. Sorry if these are newbie questions, they are. I just cant see paying anyone to touch my bike, in their shop, with me not knowing at least HOW to do it if it is something I can do myself. Down the road, if I choose not to wrestle tires and pay someone, at least I know what I'm paying them for
Old Apr 26, 2008 | 07:24 PM
jlphillips's Avatar
jlphillips
Default RE: Tire change question...
No sealant on the bead from the factory. They just dont like to come off sometimes. Saopy water will does the trick to get them on and you won't run into any problems.
Old Apr 26, 2008 | 10:32 PM
bluechiphank's Avatar
bluechiphank
lube that old tire with soapy water too it will help it slide off as us tire guys say always lube your rubber
Iron lHorse
Oct 13, 2015 04:48 PM
Jeff's 1st Harley
Feb 5, 2012 06:30 AM
bobbyd3
Oct 21, 2010 05:32 AM
Merlinrocks
Mar 22, 2007 01:24 PM
mndemohead
Oct 4, 2005 09:27 AM
