Tire changer question
Old Feb 4, 2012 | 06:33 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Default Tire changer question
Well went out to the shed today and discovered my back tire was flat. Took out my service manual and took the wheel and tire off. Drove twenty miles to the Harley joint and nearly had a heart attack. I had one of those socket head screws in the middle of the tire. The tech wouldn't put a new tube in it unless I bought a new tire for 334.00 dollars. I said wow, i mean wow. Told him I could get two of them at the motorcycle superstore for less than that. So my question is what type of tire changer do you guys have and recommend. Don't want to spend alot of money, but want something that will work. Any suggestions guys. Sorry for the long post, but a little mark-up I can see, but more than twice the price of a new tire, sheeeeze.
Old Feb 4, 2012 | 07:19 PM
desertrideryz's Avatar
desertrideryz
Try a Indy. Or i took mine to the Kawasaki dealer i got a Metzler 880 on the bike for @ 200.00
Old Feb 4, 2012 | 08:23 PM
shadowbob's Avatar
shadowbob
use a large c clamp to break the bead, and a couple of small tire spoons and a lot of dish soap diluted with water for lube. use dyna beads to balance when its all back together
Old Feb 4, 2012 | 08:41 PM
ynots's Avatar
ynots
Sounds like what your describing is a hex head sheet metal screw. smooth up the inside of the tire and glue a patch where the hole is. Order 2 tire spoons from the superstore and mount it yourself.
Old Feb 5, 2012 | 06:30 AM
Jeff's 1st Harley
Thanks Shadow and yknots. That is exactly what I intend to do. Thanks for the reply.
Grey_Fox
Dec 3, 2015 09:24 AM
Iron lHorse
Oct 13, 2015 04:48 PM
BlueNoser
Mar 28, 2011 02:27 PM
TurkeyRun
Apr 26, 2008 10:32 PM
mndemohead
Oct 4, 2005 09:27 AM
