Exhaust Stud Removal
Old Apr 27, 2008 | 09:43 AM
0ut1aw's Avatar
0ut1aw
Default Exhaust Stud Removal
Several months back I had a problem when putting my exhaust back on. The engine was warm the nut for my exhaust got a little cross threaded. When I went to tighten it down the stud turned into the head. There was just enough to hold the pipes on so I ran it that way. Yesterday I decided its time to fix it. Simple half turn on the nut and it came off. Then I had to get the stud out.
First I tried the good old vise grips. The stud was in too tight and the wrong location for this to work. It was the rear cylinder top stud. So next I fired up the engine and got her good and hot, only thing this did was burn my fingers, no luck budging the stud. I tried one of these http://www.sears.com/shc/s/p_10153_1...d=stud+removerbut not enough room.
I tried to drive a socket on the end and turn it out, no good.
I finally went down to sears and bought a stud remover small enough to work, drove it on the stud and she came out like butter.
If you ever need to remove a stud, try these they work pretty well. http://www.sears.com/shc/s/p_10153_1...rd=nut+remover
[IMG]local://upfiles/19128/87CAA39F9BAF41A789C50393D0BE8591.jpg[/IMG]
Old Apr 27, 2008 | 10:20 AM
redrubicon2004's Avatar
redrubicon2004
Default RE: Exhaust Stud Removal
Glad to hear it worked out for ya. I'll have to pick up some of those next time I am in Sears.
Old Apr 27, 2008 | 10:29 AM
mikeurig's Avatar
mikeurig
Thanks for the tip. Something to use my coupon for.
Old Apr 27, 2008 | 12:01 PM
0ut1aw's Avatar
0ut1aw
The smallest size in that pkg fit the stud at it only cost 20 Bucks.... A deal since it worked
Old Apr 27, 2008 | 12:15 PM
JRK5892's Avatar
JRK5892
ha ha ha my girl was at Sears when i read this! just called her and told her to pick it up... thanks for posting pics, i was able to just email that pic to her... that way i will not end up wiht a screwdriver ... thanks for the heads up!
Old Dec 21, 2011 | 10:16 AM
Drjas's Avatar
Drjas
6th Gear
Thanks for the advice Outlaw - the link doesn't work anymore(?) Do you have a product number or otherwise? Thanks.
Old Dec 21, 2011 | 03:26 PM
monkeyboy22's Avatar
monkeyboy22
Don't know if this is the exact item the OP was refering to but, probably one of these.
Old Dec 21, 2011 | 05:39 PM
AFONE's Avatar
AFONE
I had to do the same thing. The trick is to run the engine first and let it idle and get hot. Once the metal heats up and expands it's a lot easier to back out the stud using pliers or vice grips.
Old Dec 21, 2011 | 06:02 PM
GREENOHAWK69's Avatar
GREENOHAWK69
My Dad had suggested before installing the exhaust stud, that I should cut an "X" into the end of the stud not going into the engine. Then I could use a phillips head screwdriver to remove.
Old Dec 22, 2011 | 04:26 AM
clicker01's Avatar
clicker01
Google> sears 00952060000
http://www.google.com/products/detai...79330136093412
