Side License Plate Light...
Old Apr 29, 2008 | 02:26 PM
jaska69's Avatar
jaska69
Default RE: Side License Plate Light...
Hi! I understand above that blue wire under the seat(going under rear fender) is parklight?? is it correct??
So i can make joint to licenceplate 2 led + wires with that? no harm with alarm or something ??
Maybe I must test it with volt meter before cutting wires for sure...
Can you Rmblon put little bigger picture about that tail light wiring??
which black is rightone for ground, or are they all - wires?
Or is it better joint -wire direct to frame?
Old Apr 29, 2008 | 04:56 PM
RMBLON's Avatar
RMBLON
See if this scan is any better.
[IMG]local://upfiles/37540/6079A440D8A4490BA7937D33032B3A90.jpg[/IMG]
Old Apr 30, 2008 | 07:57 AM
jaska69's Avatar
jaska69
Thanx!!
Old Apr 30, 2008 | 10:06 AM
dav.elis's Avatar
dav.elis
I have not understood. So I must cut the blu wire that go in the 4-pin tail lamp and go to the side licence plate, or I must connect it only?
(I would have a sidemount too, thanks).
Old Apr 30, 2008 | 01:16 PM
jaska69's Avatar
jaska69
You must share blue(+) wire with tail light and side mount licence plate light .
I share black(-) wire also near that connector where taillight wires go under rear fender.
I´m not sure is it correctly right, but lights work fine now
Old Oct 21, 2008 | 10:33 PM
rockon's Avatar
rockon
Saw this thread and figured I'd give a definitive answer for any '08 riders out there. Just checked my Service Manual for the same info, and you'll want to use the blue wire (not the red/yellow one) that runs into the tail light. Blue is the running light, red/yellow is the brake.
For anyone with a service manual, it's Figure B-20 in the back.
littledawg
Apr 21, 2014 08:04 AM
Lone Dawg
Apr 15, 2013 06:42 AM
Buggz
Jan 23, 2009 09:26 AM
hogdiver96
Aug 28, 2008 10:43 AM
so cal 450
VRSC Models
Apr 2, 2007 10:44 PM
