Noisy front end
Old May 5, 2008 | 07:52 PM
coop creek's Avatar
coop creek
Default Noisy front end
Hey, is this normal? My '07 low rider really rattles over bumps, its a metallic, loose rattle, not a clunk, coming from the steering head or somewhere out there in front.I had the steering head bearings adjusted by the dealer last week and he said I should feel a difference, but nope, it still rattles, especially over prolonged, bumpy road surfaces. I told him about the service bulletin for replacing that washer but I don't think they did that.
Old May 5, 2008 | 08:14 PM
murphdog's Avatar
murphdog
Default RE: Noisy front end
It's not normal, there shouldn't be any rattling. Check your tank mounting bolts, heat shields, kickstand bumper, dash, front fender and anything else you can grab with your hand and see if it's loose. The rear brake pedal and rod rattled on my FXDC and I shimmed them with thin washers. You can buy the steering stem washer for a couple bucks and do it yourself if you want it done. You may have to take the handlebar off to get at the nut with your pullback risers, but it's not a big deal.
Old May 6, 2008 | 04:39 AM
encorebilly's Avatar
encorebilly
Try gas cap.
Old May 6, 2008 | 08:04 AM
dyna07custom's Avatar
dyna07custom
Check front brake calliper mine came loose
Old May 6, 2008 | 08:24 AM
ord sgt's Avatar
ord sgt
My '07Street Bob had the front end clunk over the bumps. Had the dealer replace the steering head nut and washer, clunk gone. At first, while riding away from dealer, ran over manhole covers, heard clunk, then realized that the covers were making the noises.
Old May 6, 2008 | 07:31 PM
coop creek's Avatar
coop creek
thanks guys, I will give everything shake-able (on the bike) a shake or two, if I can't reproducethe soundI think I'll take it back and let the dealer techs take it for a test ride themselves.
Old May 6, 2008 | 07:39 PM
rbabos's Avatar
rbabos
Don't rule out the gas cap and the headlight when you're smacking things around to find the noise. My softail was the headlight bottoming out inside on the rubbers.
Ron
Old May 6, 2008 | 08:18 PM
rayfinseats's Avatar
rayfinseats
I have an 06 Superglide. No rattles here.
Old May 6, 2008 | 08:29 PM
TheGuyWhoPosted's Avatar
TheGuyWhoPosted
sounds like my 06 Bob. My rattle is the tank. I had a tank lift took it off and now I have a close but not close enough diameter bolt in there. I'd try shaking the tank up and down when the bike is parked and see if that is the sound you're hearing.
Old May 6, 2008 | 08:40 PM
maddghost's Avatar
maddghost
When I got my bike with detachable backrest I was hearing rattles each time I reved the engine or hit a bump. It was the mounting lugs.The dealer told me it was normal.I said WHAT? He sid those were the original and only parts made for this assembly. I ended up putting electricians tape around themounts to take up extra girth'
