Wind deflectors for Dyna?
Old May 11, 2008 | 11:48 AM
GaryInSanDiego's Avatar
GaryInSanDiego
Default RE: Wind deflectors for Dyna?
ORIGINAL: Biker Bob
ORIGINAL: GaryInSanDiego
Rich,
Isketched them freehand using the same basic shape as the original deflectors, and cut them out with a sabre saw. The final dimensions are about 6" wide at the top and 5.5 inches wide where they start to curve at the bottom. Total height is about 11". I bought a piece of 1/4" clear scrap plastic at a local shop. I think I paid about $2. After I cut them out, I softened the plastic in the oven and curved them slightly. You have to make sure both of them are cut identical, or you may have some problems with aerodynamics.
How about a picture? BB
Here ya go - pens are to show scale.
[IMG]local://upfiles/40722/F4CE078118514CA2BD0FEA06926E642B.jpg[/IMG]
Old May 14, 2008 | 02:39 PM
richdeerht's Avatar
richdeerht
Gary-
I made a set for my FXDC and they are definitely an improvement. I have not yet bent them, but tried them outstill being flat.
I'm looking for a little more detail on the bend procedure. How hot and how long did you bake them? Did you use a form to bend them over?
Thanks.
Old May 14, 2008 | 02:48 PM
Stanger's Avatar
Stanger
ORIGINAL: Biker Bob
Rich,
Good job, looks good and practical! I assume they work fairly well.
Old May 14, 2008 | 07:15 PM
CCPD's Avatar
CCPD
Someone has altered a forkair baffle from a touring bike to fit on their Dyna
https://www.hdforums.com/m_3109405/m...tm.htm#3109405
Chris
Old May 14, 2008 | 07:36 PM
itileman's Avatar
itileman
I used the HD black baffle on my Lowrider without any modifications. You wouldn't notice it if you were'nt looking for it. Helps some, well worth the $12.00 and 3 minutes of install time.
Old May 14, 2008 | 07:46 PM
GaryInSanDiego
Yes, my homemade lowers work very well. They completely eliminate the updraft. I still get some turbulence over the top of the ws, but there's not much I know ofthat can be done about that.
Rich - I heated them in my kitchen oven, but I don'tremember exactly what the setting was. Start out very low and then slowly increase until they just barely bend. If they get too warm, they will be like a pancake, and you'll never get them back to the original shape. I experimented first with a piece of scrap. I used an old windshield as a form for bending.
LADNAR
Oct 15, 2013 11:10 AM
bob moore
May 28, 2011 06:10 PM
ORCUTTHD
May 14, 2010 05:46 PM
ajay450
Feb 16, 2009 09:44 PM
GaryInSanDiego
Sep 10, 2007 10:56 PM
