Will it fit?
Old May 13, 2008 | 02:33 PM
2007fxdc's Avatar
2007fxdc
Default RE: Will it fit?
I have a full size Ram with a 6.5' box (78"). I haven't tried it yet but I've taken some measurements and mine "should" barely fit straight in with the front wheel in a chock and the rear wheel contact patch sitting on the back edge of the box with the tailgate down. You are working with a box that is 14" shorter so you are certainly looking at the rear wheel sitting on the tailgate. I, too, have seen plenty of people hauling bikes that way and I had no idea that the rear wheel being on the tailgate was a bad thing. Why is that anyway? Is it because of weight? If so, you could put something in the bed of the truck that overlays the tailgate and roll the bike on over it so that some of the weight can be redistributed back into the bed of the truck.
What I'm hoping to do is haul my bike in the back of my truck so I can take it with me when I'm pulling my RV trailer. I can't pull the RV with the tailgate down so I'm hoping for enough clearance to get the bike stable in the bed of the truck and then remove the tailgate for hauling/towing. I have a chock but I don't have a ramp yet. So, I haven't tested it so far.
I've seen people do it but I don't feel comfortable loading at an angle because, to unload, the bike has to be moved back and that's hard to do, especially in a tight space and would almost certainly require capable help.
Old May 14, 2008 | 06:20 AM
HarleypsychRN's Avatar
HarleypsychRN
I've seen people shoehorn their bikes in a 45 degree in the bed and close the gait but could never figure out hoe the heck they did it.
Old May 14, 2008 | 07:40 AM
ken01976's Avatar
ken01976
Yes it will fit. We haul my brothers victory 8ball in the same truck with the tail down. Sideways.
Old May 15, 2008 | 07:19 AM
Dakota Bob's Avatar
Dakota Bob
Stage III
Thanks to everyone for your input! I appreciate all the advice. I think I'm going to end up purchasing a trailer or renting a Uhaul.
Old May 15, 2008 | 07:34 AM
chesterman's Avatar
chesterman
I've put my Street Bob in my Dakota Crew Cab and hauled it for a 12 hour drive. Just pull the bike in on the left side of the box and then crank the bars to the right. Place the front tire in the front/passenger side corner of the box and turn the handlebars as far right as they'll go. I did grab under the rear fender and slide the rear tire as far left as it would go. The rear tire contact patch will sit about perfect in the gap between the bed and the tailgate. No problems for the entire 12 hour trip, just make sure to check your tie downs every time you stop for gas.
Old May 15, 2008 | 07:39 AM
maddghost's Avatar
maddghost
Uh not to appear crass or anything ,but don't you have a tape measure?
G92069
Audio Systems
Jul 9, 2017 08:47 PM
Springerfan
Audio Systems
Feb 27, 2017 01:04 PM
pshaw09
Audio Systems
Nov 16, 2016 03:02 PM
fxesuperglide77
Sep 14, 2007 08:08 PM
klagair
Apr 13, 2006 08:52 PM
