Changing out the speedometer
Old May 13, 2008 | 07:49 AM
ssls6's Avatar
ssls6
Default Changing out the speedometer
I'm changing out my speedometer on my 08 FXDWG with a combo speed/tach unit. I have the console flipped over and all the wire harness connectors removed but one. The wire harness is connected to the trip button and I don't know how it disconnects. How do you remove the wire harness from the trip button?
Thanks,
Richard
Old May 13, 2008 | 09:06 AM
Dynaflyer's Avatar
Dynaflyer
Default RE: Changing out the speedometer
Is the trip button still connected to the console? If so remove the rubber bootie and there should be a plastic nut to remove, which will allow you to remove the trip reset button.
Not sure if this helps.
Old May 13, 2008 | 11:16 AM
USMC7236's Avatar
USMC7236
Just grab the rubber, squeeze a little and it should unscrew no problem. I just checked my manual, FXDWG "Unscrew rubber boot".
Old May 13, 2008 | 11:21 AM
davidsdad's Avatar
davidsdad
Do not try to remove the rubber boot alone. I comes off by unscrewing it....
Old May 13, 2008 | 09:44 PM
ssls6's Avatar
ssls6
Thanks guys, I really appreciate the help.
jcanrun
Electrical/Lighting/Alarm
Jul 18, 2016 05:29 PM
Architect
EVO
15
Apr 16, 2014 09:30 AM
drmichealj
Sep 22, 2013 11:28 AM
Da Butcher
Jul 22, 2009 11:03 PM
dustinw58
Jan 12, 2008 08:04 PM
