H-D Forward Control Install Warning!!!
Old May 26, 2008 | 10:32 PM
evansf_fde's Avatar
evansf_fde
Default RE: H-D Forward Control Install Warning!!!
I installed forward controls from drag specialties.....
I left the shaft in (did not saw it off or anything)...put it out of the way as suggested on the in the forum...capped it so it stayed in place...no problems with neutral.
evansf_fde's Avatar
evansf_fde
Forwards installed on 2006 Dyna Low Rider
Old May 26, 2008 | 10:54 PM
OldNo7's Avatar
OldNo7
I fitted HD forward controls myself and left the "short" rear arm and mid control sa they were and had no problems in finding "N" up or down. I did eventually get the stealer to remove the mid and fit the "longer" purely for looks and wasnt keen on the mid lever left hanging. Either way finding "N" wasnt a problem.
Old May 26, 2008 | 11:15 PM
WS6 Formula's Avatar
WS6 Formula
Raiderse,
I think you just need to practice going into neutral.Try not moving the lever as much, it doesn't take much movement to go into neutral. I have over eight thousand miles on my forward control set upand have not had a problem.
I did a search on your posts, you may want to re-readall the posts in thisone: https://www.hdforums.com/m_3423418/tm.htm
Old May 26, 2008 | 11:27 PM
Zevron's Avatar
Zevron
I really like my HD forewards. I paid the dealer to put them on. I am not that good of a mechanic.
Old May 27, 2008 | 12:53 AM
TOMMAY's Avatar
TOMMAY
If you haven't already done so,you might consider replacing the factory shift rod with the Harley or aftermarket shift rod with heim ends. Sounds like there's some slop in your linkage somewhere.
Good Luck
Tom
Old May 27, 2008 | 05:04 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Been thinking about the remark concerning holding in the clutch, but when I stop I have the bike in 1st, with the front end aimed towards some clear space. I've been rear ended twice in a car so I watch the mirrors very closely while I'm stopped. My thinking is if I see someone approaching too fast from the rear that I can scoot out of the way. I don't think holding in the clutch causes excessive wear, been doing this for a long time.
Old May 27, 2008 | 05:35 AM
Raiderse's Avatar
Raiderse
ORIGINAL: Lopoetve
you're wrong about it wearing the clutch - it's just hard on your hand to hold it in. It's safer though.
It doesn;t wear the clutch but I believe it it hard on the throwout bearing.
Old May 27, 2008 | 05:37 AM
Raiderse's Avatar
Raiderse
ORIGINAL: subculture08
I opted to have the dealer put them on my 06.
He gave me a great deal on the instal off season and I figure that I have saved lots of cash using the manual and this forum so what the hell. Getter' done right. Just MOP
Agreed, but I just wanted people to be aware of this because they (like me) may not be prepared for the extra cost which is considerable.
THis isnt a rant , just a "watch-out" or "Warning"
Old May 27, 2008 | 05:40 AM
Raiderse's Avatar
Raiderse
ORIGINAL: Slipstrm
Dam...suck it up and be Harley man!
I can get mine into neutral from second every time and since I went to a heavier fluid I can get neutral from first most times.
I bet yourlittle sistercould do it...hundreds of us have done it this way...you should immediately sell me your Dyna before its too late....and If you cant hack it maybe you should just buy a Honda and move along.
Been on Harleys since '90 this is my Sixth new Harley. 90 883 Sportster 91 1200 Sportster 82 Wide Glide, '04 RoadKing, '04 ElectraGlide Classic and now '08 DYNA. I have a couple around , never had one that I couldn;t find neutral, I guess Honda must have been making these forquite some time.
