What to do?
Old May 27, 2008 | 02:09 PM
firemedic58's Avatar
firemedic58
Default What to do?
I have an 07 SB with a SE 103 stage II, which was installed by the dealer prior to when I purchased the bike new. I recently installed a set of V&H bigshots, and am wondering if I need to re-map my ECU. I've talked with a coulple local dealers who both said I needed to buy the SERT and put the bike on a dyno to create the best results; about $1000 when it's said and done. So do I have any other options? PCIII etc., just a re-map,or do I even need to do anything? The bike seems to be running fine and I have no intention on doing any further engine work. Not real clear on what needs to happen, my main concern is I don't wan't to put too many miles on the bike if it's running too lean or rich. Thanks in advance for any help/suggestions. -Ed
Old May 27, 2008 | 02:27 PM
2007fxdc's Avatar
2007fxdc
Default RE: What to do?
ORIGINAL: firemedic58
If the bike seems to be running fine and your main concern is the air/fuel mix, just get it checked on a dyno. Your bike likely has a stage II download in the ECM already if there is no evidence of any other devices. So, it may be fine. To do a quick check, pull the plugs and see if they are white or brown. Too white and you are too lean, too brown and you are too rich. You want something in between like a light brown.
Old May 27, 2008 | 03:59 PM
SK8ROD's Avatar
SK8ROD
i think you would get the best out of it if you went the PCIII, SERT route... put it this way, i would buy a PCIII straight off, right now and head down the local dyno...
Old May 27, 2008 | 04:30 PM
labfreak's Avatar
labfreak
If the dealer put in the 103 etc. you are fine, forget what anybody tells you. You are a stage 2, and I am sure they would not send that bike out the door without an adequate fuel mix.
Old May 27, 2008 | 04:33 PM
cornishman's Avatar
cornishman
My advice for what its worth is eithera PC111 or SERT.
With the money you have put into your bike it deserves to be set up to its best potential. Sure the plugs may look good but a good tuner will always get it to run at its max. That will give you the benefits right across the board, fuel consumption performance sweet running, and you ain,t gonna know till its tuned.
The SERT / PC111aregreat pieces of kit and you need a tuner that can work with them so you,ll need to do some homework to find who,s who in your area.
When your done then you,ll know for sure your moneys well spent.
JMHO best wishes
Old May 27, 2008 | 07:34 PM
firemedic58
Thanks for the input. Anyone think I should just get the bike on the dyno and have the re-map done rather than getting a ecm programer?
Old May 27, 2008 | 08:23 PM
SkyRider's Avatar
SkyRider
if your not going to do anything more than keep your 103 kit then just geta download...it will run fine. I'm not sure why people on this site are so uppity about getting everything dynotuned. In a lot of cases it isn't needed. When I put pipes and and AC on i just downloaded a map for my PCIII and it rode beautiful. 300 dollars isn't worth the money for the extra 3 hp if you bike is running fine. The nice thing about the download from the dealer is if they do the download and your bike runs crappy you can take it back and they will have to fix it. Same thing with a SERT...PCIII's they are a little more leary on unless you spend the big bucks and buy one there. Any choice will work well for you...its all about the future and what your plans are.
Kbore
Jul 5, 2009 05:16 PM
jjr
May 26, 2007 09:14 PM
OPTPERF
Dec 13, 2006 10:08 PM
jaysonL
Aug 26, 2006 02:11 PM
jtfrog
Exhaust System Topics
Mar 29, 2006 02:14 PM
