Help making decision, Please.
Old Dec 8, 2006 | 11:11 PM
OPTPERF's Avatar
OPTPERF
6th Gear
Default Help making decision, Please.
I have an 06 Fatboy with EFI.
I have read the forums and understand the differences and pros and cons with PCIII and the SERT.
My question is this...
My bike has aftermarket pipes, SE A/C Kit, 25 degree injectors, and stage 1 download.
Bike runs great, plugs look good, no driveability issues, only minor pops on decel about 30% of the time when RPMs are high.
Dealer has told me pops are probably from excess fuel being released and igniting in the exhaust pipe, and I should not be concerned about engine damage.
I would like to avoid putting money into a SERT or PCIII if I can. From what I've described, should I be worried about engine damage and go ahead and get a fuel management system, or just ride it. Pops don't bother me, just don't want to have damage later on.
Old Dec 8, 2006 | 11:17 PM
dawg's Avatar
dawg
Default RE: Help making decision, Please.
Welcome. If it were me, I would go with a PCIII for $270 and get a dyno tune. That'll take care of any pops and give you a smooth fast ride, not to mention peace of mind.
Old Dec 8, 2006 | 11:24 PM
nvsteve's Avatar
nvsteve
Dealer may be correct but most of the time it's a lean pop.
I like PC111s but certainly nothing wrong with a SERT.
You can get a PC111 from Fuelmoto for under $300 shipped with a map.
It probably won't be perfect but will be close. If you decide to do the PC
be sure to tell them you have the Stage 1 download.
Old Dec 9, 2006 | 12:52 AM
FXSTI Guy's Avatar
FXSTI Guy
If your bike is running good now and you can live with the pop I doubt you'll hurt anything by leaving it as-is but a PCIII/SERT will make it run better.
Old Dec 9, 2006 | 06:00 AM
OneBlackFly's Avatar
OneBlackFly
I've about the same detup and was told by two dealers that all is fine, not to waste my money on a dyno tune, just have it checked that map is correct (with either Scanilyzer or DigiTech)
Old Dec 9, 2006 | 06:07 AM
DI75's Avatar
DI75
WILL MAKE IT RUNS LOTS BETTER WITH A GOOD DYNO GUY!!!
Old Dec 9, 2006 | 04:16 PM
Uncle Peepers's Avatar
Uncle Peepers
I'd be very much inclined to leave it alone. What do your plugs look like? Specifically the "burn-back", meaning at what point does the color of the electrode go from light to dark? Also, what color is the insulator?
Uncle Peepers
Old Dec 9, 2006 | 07:49 PM
OPTPERF's Avatar
OPTPERF
6th Gear
electrode is dark on top/flat part and gray/tan on sides.
insulator is clean white with a tannish tint.
My concern about PCIII is there seem to be a lot of people on here who have had failures and sometimes damaged the ECM.
I am all about leaving things alone if I can. I don't plan any engine mods. If I do in the future I would purchase a FMS then.
Pretty sure my download is correct, it was just reloaded when they changed my injectors a few weeks ago.
Old Dec 9, 2006 | 08:16 PM
pittguy's Avatar
pittguy
Things fail and some of it has to do w/owners own doing.the PC has been known to retain water either in box or wiring harness.Sealing will cure and isolating the box from vibration will help.
Old Dec 10, 2006 | 01:06 AM
Uncle Peepers
I am a very big fan of the PCIII, but I don't think you need one. Your description of your plugs sounds your A/F mixture is good. I'd leave it alone.
Uncle Peepers
