30 tooth baker on 07 dyna
Old Nov 11, 2008 | 05:35 PM
jsbridgew's Avatar
jsbridgew
Let's bump this up... Anyone do this, yet?.... Bike is down for the winter and I'm looking for a season mod.
Old Nov 12, 2008 | 09:26 AM
Prodriverdon's Avatar
Prodriverdon
I bought the Baker gear about a year ago and yes I had to change the belt. Look up my posts because I posted the part # you will need. And yes it helps big time with torque and hp. I no longer have "lugging" in 6th. I use 6th gear at 55mph now.......And the 2" socket is more than the gear itself. I borrowed one from the old Indian dealer...
Old Nov 12, 2008 | 11:23 AM
jsbridgew's Avatar
jsbridgew
Is that the only tool we need, "Prodriverdon"? ...the 2 1/4 socket to remove it?
Old Nov 12, 2008 | 12:35 PM
paul s's Avatar
paul s
If you go with the 31T the stock belt is good. The 30T needs a shorter belt.
Old Nov 13, 2008 | 09:32 AM
Prodriverdon
I went with the Baker 30 tooth gear,part # 1100-0010 and I had to change the belt. If you buy the 2 1/4 socket from Baker part # 3802-0029 it is $153. All you need is the socket and normal shop tools.......And Locktite as needed.
Old Nov 13, 2008 | 09:46 AM
rounder's Avatar
rounder
may need to use an impact wrench depending on your ability to get the compensator and sprocket nuts off.
Old Nov 13, 2008 | 09:55 AM
jsbridgew's Avatar
jsbridgew
wow, that sprocket's expensive!... George's garage sells it for about $92.00
http://www.georges-garage.com/trans_primary_tools.htm
Old Nov 13, 2008 | 10:29 AM
jsbridgew's Avatar
jsbridgew
Alright, I've been all over the internet and checked everywhere
...I think
Where the hell do you buy this sprocket?
Old Nov 13, 2008 | 10:33 AM
paul s's Avatar
paul s
http://www.bakerdrivetrain.com/cruis...ex.htm#pullies I'm going with the 31T.
Old Nov 13, 2008 | 12:00 PM
markrumsfield's Avatar
markrumsfield
Just wonderin how far does the 30 tooth throw off the speedo?
