Speedometer options on a Super Glide
Old May 30, 2008 | 02:07 PM
bberck's Avatar
bberck
Default Speedometer options on a Super Glide
So far I love my new Super Glide but I am not crazy about the Speedometer Housing. I am sure there are lots of option I would just like to see some pics.
I like how my buddies Custom Sportster set up is but not sure if thats a option or not.
Thanks
Old May 30, 2008 | 04:36 PM
jim425's Avatar
jim425
Default RE: Speedometer options on a Super Glide
You can buy a Chrome Housing if you are talking about a bar mounted speedometer. That's what I did. It's a relatively easy change. I also replaced my risers with chrome ones. If you look around you can probably find a takeoff.
Old May 30, 2008 | 05:06 PM
Frankster69's Avatar
Frankster69
Yeah Jim that's what I did also
expy's Avatar
expy
Paint it unless your bike is black of course. $10.00 to do mine. https://www.hdforums.com/m_3362875/tm.htm Link to original post
Old May 30, 2008 | 05:09 PM
Frankster69
Where did you get the bra at Expy looks good
Old May 30, 2008 | 05:18 PM
expy's Avatar
expy
Sorry Frank I if I'm wrong but I think you talking about the chrome center console on the tank? ItsHD part # 67188-04
Old May 30, 2008 | 05:28 PM
WildBillAce2's Avatar
WildBillAce2
+1 on the chrome housing, makes it look better. The only other real option is to get a wide glide or lowrider tank, but then you are talking about paint, console, guages, big bucks....
Old May 30, 2008 | 06:58 PM
bberck's Avatar
bberck
I saw a pic of one that had a double chrome housing and added a tach. I liked the looks of that.
Old May 30, 2008 | 08:24 PM
simsjam's Avatar
simsjam
You can change out the whole assembly like I did (look at my old posts). I swapped mine out with an 04 and up XL Custom setup I got off Ebay from a wrecked 883. Moves the speedo down under the bar clamp. It was all plug and play for my 06 FXDI. As long as you have no tank lift there is plenty of room between it and the gas cap. The bad part is you are stuck with that riser forever because it is part of the speedo housing.
DynaJ
Jun 1, 2016 06:00 PM
Raineman
Sep 9, 2013 09:11 AM
kamut
Apr 1, 2010 03:56 PM
Mebeebo
Mar 3, 2010 11:53 PM
Jorday
Mar 22, 2007 06:20 AM
