Speedway Instruments micro tach
Old May 30, 2008 | 06:06 PM
Patch's Avatar
Patch
Default Speedway Instruments micro tach
www.speedwayinstruments.com
Does anyone have one of these and if so where did you install it and how do you like it?
I have a 2005 FXDCI and am thinking about putting it on the front brake master brake resivour.
Thanks
Old May 30, 2008 | 06:23 PM
2002fxdp's Avatar
2002fxdp
Default RE: Speedway Instruments micro tach
certainly watchin this thread.
i like that it so small, wish they made speedos too
Old May 30, 2008 | 09:52 PM
USMC7236's Avatar
USMC7236
That does look really cool. Only $149. I think I may "need" one.
Old May 30, 2008 | 09:56 PM
rfranz1952's Avatar
rfranz1952
I bought one of the first ones they made.
Works great, I've got it mounted on the brake resevoir. Very visible, even in bright daylight. Also dead on accurate.
Old May 31, 2008 | 09:13 AM
joeld0803's Avatar
joeld0803
It looks like it only has a spot for 2 digits unless I am mistaken.
How many digits does it display? I would think it needs at least 4.
Old May 31, 2008 | 09:39 AM
2002fxdp's Avatar
2002fxdp
only 2 digits
Old May 31, 2008 | 11:43 AM
BluBob's Avatar
BluBob
rfranz,
How well does the redline "flash" work? Can you notice it without looking directly at it (shift light). Is it settable or just preset? Dou you have to plug into the ECM harness, or what? Thanks.
Old May 31, 2008 | 12:34 PM
damerleball's Avatar
damerleball
That's cool looking and different, because it's digital and small, unlike any Harley guage which are always a dialog. I like that though.
Old May 31, 2008 | 07:38 PM
rfranz1952's Avatar
rfranz1952
The redline "flash" is preset to 5800, I believe, and is not adjustable.
I normally don't use it, so I don't pay much attention to it. It is, however, pretty noticable.
I've had mine long enough, I'm having difficulty remembering how it wires in. I think, in my case, that it attached to the data bus wire using a suitcase connector in side the riser. I got it hooked up on the first try, so it must have come with good instructions.
Generally, if its possible, I will screw it up![]
Some of the comments are correct--it does read in two digits--in hundreds. 42 = 4,200. Pretty easy, and one of the reasons it can be both readable and small. I don't even remember the last time I needed to know if the engine was turning at 4230 vs 4240 rpm
Speedway apparently now has a choice of chrome or black. When I got mine, it was like the model T--you could buy black, or you could buy black. Worked for me, because my brake resevoir was black.
Apr 17, 2019 02:53 PM
Infrigger
Aug 10, 2011 10:50 PM
jserigne
Ironhead
May 28, 2008 07:39 AM
sulconst2
May 13, 2008 08:06 AM
sbdynafan
Mar 4, 2008 04:35 PM
