Rear fender rack on SB
Old Jun 3, 2008 | 05:06 PM
flynavy's Avatar
flynavy
Default Rear fender rack on SB
I have noticed a few Street Bobs on the forum with the rack behind the solo seat on the rear fender.
I am getting my gear together for a trip to Sturgis and one of these racks would fit the bill for my needs on my 07 SB.
Can anyone help me out with:
vendor
part number
link
Does it simply mount to the fender via the seat nuts? Does one end mount under the solo seat nut and the other on the two-up nut?
Help a brotha out if ya can spare the typing....
Old Jun 3, 2008 | 05:07 PM
Punty's Avatar
Punty
Default RE: Rear fender rack on SB
Its a Motherwell rack, I beleive that they are even a sponsor here. I got mine on ebay used. They come in Black and chrome. and it bolts right up.
good luck
Old Jun 3, 2008 | 05:26 PM
flynavy's Avatar
flynavy
can it be used at the same time as the HD removable luggage rack/backrest...or it use one or the other?
Old Jun 3, 2008 | 05:28 PM
RMBLON's Avatar
RMBLON
Here is a link to Motherwell part# MWL-530
http://www.motherwellproducts.com/So...-p/mwl-530.htm
You will need a special nut, the same one the rear nut for the seat uses, attaches to the fender from under the fender and is held in place with a clip, HD will have them. Basically there is a hole at the back of the fender with a Rubber plug in it, remove it and install that nut. Here is a pic.
[IMG]local://upfiles/37540/98D144EFEAA3440FB2BA317577AA801A.jpg[/IMG]
Old Jun 3, 2008 | 05:31 PM
Nickpisp's Avatar
Nickpisp
Don't order one from The Hawg Trough on Ebay. It's been 2 1/2 weeks and they just shipped it today.....
Old Jun 3, 2008 | 06:02 PM
Chipstah's Avatar
Chipstah
ORIGINAL: flynavy
Can't see why it wouldn't work. Ought to be able to tell from the pic below. And motherwell also has the nut you need -- very good customer support and fast shipping -- order direct from them is my recommendation. Good luck!
Old Jun 3, 2008 | 06:39 PM
SciFiGuy's Avatar
SciFiGuy
I ordered mine directly from Motherwell and it just arrived today. I also ordered the nutbut I have question about the instal since it dose not come with any insturctions what so ever.
How do you get the nut up under the fender? And does the clip attache under or above the fender?
Please forgive my ignorance but this is my first Harley and the last thing I want to do is screw up my first mod.
Thanks.
Old Jun 3, 2008 | 07:07 PM
hd_sob's Avatar
hd_sob
I've owned a couple Motherwells that I had mounted on two different scoots (XL1200C from a few years ago and my current FXDBI). I ended up removing them from both for the same reason (I wish I could have recalled why I removed it from the Sporty before buying another for the Dyna).
The way they are (were?) constructed, there is no inner, lateral (left-to-right) tubing in the construction to aid in the placement of bungee cords. Therefore, everything I ever put on it tended to slide in a fore and aft direction. It was very frustrating and I doubt I will ever buy another unless they change the design (if they haven't already).
They are good quality racks and they look nice. Just something to be aware of if you have never owned one and/or thought of how you might secure things to it.
Old Jun 3, 2008 | 08:13 PM
twofish's Avatar
twofish
http://www.motherwellproducts.com/Se...lts.asp?Cat=20
Motherwell
Old Jun 3, 2008 | 08:20 PM
Keeg's Avatar
Keeg
Place a plastic zip tie through the hole in the nut and guide it through the fender hole from underneath the fender. Then place the clip to secure the nut in place(clip above the fender).
Did you order the 7" inch solo directly from Motherwell? Their site is saying that model is out of stock.
Thanks
K
