I have seen a few posts on how easy it is to change your sliders. Can anyone elaborate a bit more, with perhaps a list of steps on how to do it with the forks mounted to the bike? I reide a 2003 wideglide
Any help would be appreciated
Cheers,
It really isn't that hard to do. Get a manual and follow the directions. When I did mine I used the triple tree as my vise to hold the forks as I loosened the top nut. Be real carefull when you take the top nut off as it is under preasure.
1. loosen the top fork cap nut.
2. remove wheel
3. Drain oil (if you have drain plugs)
4. \\;\\\\\\;Remove the bottom bolt that holds the dampner in place.
5. Remove fender and \\; remove forks from triple tree.
6. finish removing the fork cap nut (carefully it is under preasure), spacer, and spring
7. \\;\\\\\\;Remove dust cap using brass drift
8. \\;\\\\\\;Remove snap ring that \\;\\\\\\;holds in the fork seal
9. Using the upper fork as a \\;\\\\\\;slide puller pull out fork seal. \\;\\\\\\;
10. Remove dampner and remember the order that the parts went in.
11. Reverse process using new sliders.
(this is from memory when I did it a few weeks ago)
Get a fork cap socket designed for the fork cap nut. It clears the handle bars.
I used a PVC pipe to install the seal but that was for 49mm forks. I do not know what size you would need.
I used my service manual and this web page for a reference. I would add one step.
Leave the fender on the sliders until you break the hex bolts at the bottom of the sliders free. \\; Otherwise, they spin and you will pull your hair out. \\; BTW, the hex bolts require a 12mm allen wrench.
Hit me up if you have questions. \\; It's not difficult if you take your time and work methodically.
I did think of polishing them, matter of fact, I will be using the info on the "under $50.00 thread" to polish my rotors this weekend. The thing is my kids, god love them, found chrome sliders on ebay , bought them, and are going to give'em to my for fathers day. Little bird told me. Thanks Punty. ktm_scott, I will hit you if I get stuck, Airborne350G, thanks man, I do have a Climer manual, and it is fairly clear, but as always there is something to learn from this great forums. Thanks all
Cheers,
