hand grips/glue removal
Old Jun 10, 2008 | 01:21 PM
damerleball's Avatar
damerleball
Default hand grips/glue removal
I have a pair of handlebar grips on some handlebars, I had taken off for a switch out of handlebars, and the gas side grips are out but I need to get the left side one off. It is glued, and needing to know how to take that one off, with that glue on them still on the handlebar. Is there a way of doing this removal?
Old Jun 10, 2008 | 01:25 PM
SkyRider's Avatar
SkyRider
Default RE: hand grips/glue removal
brake cleen always work really well with removing any adheasive...otherwise goo gone and some heat...let the goo gone soak in though.
8541hog's Avatar
8541hog
Are you talking about stock grips?&nbsp\\; Do you want to reuse them?&nbsp\\; I cut my stock rubber ones&nbsp\\;off because I was replacing them.&nbsp\\;
Old Jun 10, 2008 | 01:30 PM
damerleball
where can i find that stuff brake cleen?
Old Jun 10, 2008 | 01:31 PM
damerleball
no there not stock grips
Old Jun 10, 2008 | 01:40 PM
tlb's Avatar
tlb
try a heat gun or blow dryer. you can buy brake cleaner at wally world or an auto parts store.
Old Jun 10, 2008 | 03:21 PM
labfreak's Avatar
labfreak
GUNK carb cleaner, sqirt it in wait 10 min twist off!
Old Jun 10, 2008 | 03:27 PM
JRK5892's Avatar
JRK5892
carb cleaner works great... will eat though everything! wash the grip completely after your done... use superglue gell to put them back on... it will hold it on and still allow you to break it loose if you have to ever take it off...
Old Jun 10, 2008 | 03:37 PM
crabs's Avatar
crabs
WD40 just spray it under the grip with the straw.wait a few minutes then just twist the grip off.It won't damage the rubber to.
cujo471
May 5, 2013 01:21 AM
mikehoius
Apr 9, 2011 02:22 PM
parts eeter
Oct 14, 2010 06:49 PM
Blacklion213
Jan 1, 2008 06:54 AM
toby34
May 4, 2007 01:43 AM
