suspension
Old Jun 11, 2008 | 10:22 PM
madden23's Avatar
madden23
Default RE: suspension
&nbsp\\;ummm... your front&nbsp\\;fork and rear shocks&nbsp\\;have to be addressed at the same time, they work together, stiffen the rear, ditto for the front, unless you want to ride a pogo stick, get the two dialed in together you'll be happy campers. Unfortunately there are no preload adjustments for the front, stock, you can add heavier fork oil, slower up and down, cut a pc. of PVC that is longer than stock metal spacer for more preload, or buy spring kit that allows some adjustability with supplied adapters, i.e. works performance. Don't forget the front when addressing the rear.
Dazzauk
EVO
Jul 9, 2016 11:16 AM
HyperM3
Jun 13, 2013 11:55 AM
jslum
Jun 15, 2012 08:10 AM
bbqbrisket
Nov 30, 2011 07:11 PM
FXDXJimmy
Nov 19, 2011 01:59 PM
