Post Fix
Old Jun 16, 2008 | 09:16 PM
icecaps's Avatar
icecaps
Reading More Posting Less
Default Post Fix
I was able to post a little bit longer post by typing it out on notepad(I'm sure Word or other programs would work) and then cut and pasting them on the forum post area.&nbsp\\; I hope this works and could be a short term solution to a hopefully temporary problem.&nbsp\\; At this point I'm just typing to make this a little bit longer to see if the forum is able to post it.&nbsp\\;
&nbsp\\;
Retyped to expand content
I was able to post a little bit longer post by typing it out on notepad(I'm sure Word or other programs would work) and then cut and pasting them on the forum post area.&nbsp\\; I hope this works and could be a short term solution to a hopefully temporary problem.&nbsp\\; At this point I'm just typing to make this a little bit longer to see if the forum is able to post it.&nbsp\\;&nbsp\\;
I was able to post a little bit longer post by typing it out on notepad(I'm sure Word or other programs would work) and then cut and pasting them on the forum post area.&nbsp\\; I hope this works and could be a short term solution to a hopefully temporary problem.&nbsp\\; At this point I'm just typing to make this a little bit longer to see if the forum is able to post it.&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;
Old Jun 16, 2008 | 09:41 PM
jbphoto's Avatar
jbphoto
Default RE: Post Fix
I've had mixed results.&nbsp\\; Some post fine using notepad and others are no different than typing directly and getting the error message.&nbsp\\; I've not been able to find any pattern to it.&nbsp\\;&nbsp\\;
UncleRon
Aug 5, 2008 07:52 AM
rydinlow
Jul 16, 2008 04:58 PM
dionne51
Jun 24, 2008 12:10 PM
wnogood
Nov 9, 2006 03:30 AM
