strange noise, what u think?
Old Jun 20, 2008 | 08:26 AM
Naz_Man's Avatar
Naz_Man
Default strange noise, what u think?
My primary chain is rubbing on the inside of my primary cover only happened after I put the lower shocks on. When I have my girl on it get worst. I took off the primary cover and you can see where the chain has been rubbing on the inside of the primary cover. in the middle right above where you adjust the primary chain. to me it looks like everything in there is closer to the primary cover then it was before I lowered it. I had the primary chain adjusted at the dealer and that didn't help at all.
&nbsp\\;
Do you think my chain is wore out?
&nbsp\\;
Do you think I need a new adjuster?
&nbsp\\;
Any ideas would be just awesome..... Could it be a major problem?
&nbsp\\;
Help please!!!!!!
&nbsp\\;
Donnie
Old Jun 20, 2008 | 09:24 AM
JRK5892's Avatar
JRK5892
Default RE: strange noise, what u think?
adjust your primary&nbsp\\; chain, it is outlined in the owners manual. the issue wiht you lowering your bike should have no bearing on how it rubs, the fact it gets worse with your old lady on has more to do with weight (not ment as a insult) her added weight puts more stain on the chain.&nbsp\\; i would adjust it and you shoudl be fine
Old Jun 20, 2008 | 09:28 AM
dyna07custom's Avatar
dyna07custom
Naz can not think of any effect lowering would have on the primary. I think hd has a kit to add self adjuster just a thought
Old Jun 21, 2008 | 07:21 AM
Naz_Man's Avatar
Naz_Man
ORIGINAL: JRK5892
adjust your primary&nbsp\\;\\\\\\; chain, it is outlined in the owners manual. the issue wiht you lowering your bike should have no bearing on how it rubs, the fact it gets worse with your old lady on has more to do with weight (not ment as a insult) her added weight puts more stain on the chain.&nbsp\\;\\\\\\; i would adjust it and you shoudl be fine
&nbsp\\;
Had the primary chain adjusted at the dealer.... didn't make a difference?
&nbsp\\;
Thanks for the replies guys.... any other ideas?
&nbsp\\;
Donnie
toastervet
Oct 30, 2022 07:50 AM
deadman77
Aug 5, 2008 07:40 AM
08UC
Aug 3, 2008 06:17 AM
99superglide
Jul 19, 2008 12:30 AM
Garemlin
Jun 21, 2008 11:41 AM
