Ok, this may be an ignorant question, but here it goes. Am looking at putting the chrome speedo bracket on my 08SG part number 67293-95. It says I will require two screws and spacers, that I can understand. What I dont get is the need for the handlebar accessory clamps, bracket should bolt onto top of handlebar clamp, I dont see the need for accessory clamps, was hoping someone else has done this and could clear it up for me. Thanks once again.
That one is for the older style that mounted different than your 08.
If you just want to replace the stock one with chrome, you will need the stock one off a 08 (maybe other years) Low rider 1200 sportster. Dont know the part number since it would be in the sportster parts catalog.
agree with bberck, you are looking at an older model bracket.
One option is to get the speedo bracket for a 2006 FXDC. In 2006 the FXDC did not have a tank mounted speedo.
that should work - sorry - don't have the PN - you will also need the chrome back plate - about $130 for both last I checked.
Thanks again Fellas!
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; The book I have said 05 and later, but isnt the first time I have had bad info.
 \\;\\\\\\; \\;\\\\\\; \\;\\\\\\;  \\;\\\\\\; \\;\\\\\\; \\;\\\\\\; \\;\\ \\\\; \\;\\\\\\; \\;\\\\\\; \\;\\\\\\;  \\;\\\\\\; \\;\\\\\\; \\;\\\\\\;  \\;\\\\\\; \\;\\\\\\; \\;\\\\\\; \\;\\ \\\\; \\;\\\\\\; \\;\\\\\\; \\;\\\\\\;  \\;\\\\\\; \\;\\\\\\; \\;\\\\\\;  \\;\\\\\\; \\;\\\\\\; \\;\\\\\\; \\;\\ \\\\; The book I have said 05 and later, but isnt the first time I have had bad info.
Check there wbsite for updated years on parts. The first turn signal relocater I got said 06 and up on the box but if checked the number on the website it showed just 06/07 and wouldnt work on a 08.
