Tach
Old Mar 7, 2006 | 05:14 PM
Patch's Avatar
Patch
Default Tach
I have a 2005 FXDCI-dyna/custom
I'm trying to get ideas & photos for what you have done to add a tachometer to the single speedo that's on there????
Old Mar 7, 2006 | 06:14 PM
Seabass's Avatar
Seabass
Default RE: Tach
All you have to do is by a new handlebar clamp for an 04. The 05 is a complete housing for a single unit the 04 clamp allows you to add the double bracet to hold both units. (Tach and Speedo) Follow the directions that come with the install kit. The Tach just plugs in no wiring or anything complicated. The only this Harley tells you you have to buy spacers and longer bolts. I did not use them thought they were ugly. They only change the viewing angle a little.
[IMG]local://upfiles/4682/EC3C5C00F96A4064BC6A5C2B8BFC1736.jpg[/IMG]
[IMG]local://upfiles/4682/A4E4443DCB6E46A8980BBB2FF1C9D162.jpg[/IMG]
Old Mar 7, 2006 | 06:22 PM
atrox88's Avatar
atrox88
Default RE: Tach
Patch, look further down in this forum under Mini apes and guages and you will see the setup on my bike with the dual guage setup.
It shows them from a couple of different angles.
ORIGINAL: Patch
Old Mar 7, 2006 | 08:28 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: Tach
Heh heh heh.....mine came with a tach
musicnbikes
EVO
19
Mar 16, 2014 04:41 PM
Kevin714
Mar 21, 2013 12:22 AM
JayFromPa
Nov 17, 2007 10:23 PM
richdeerht
Sep 7, 2007 03:14 PM
carltex
Nov 28, 2006 09:43 PM
