Hi all
I just got a set of passenger peg mounts for my bob.
I am reading the instructions and to install
left side mount the instructions are telling me to
loosen axel nut and loosen axel adjusters.
Can't I just remove the belt guard mounting bracket
and install rear peg mount in its place?
The instructions seem a little more involve than they need to be
OR AM I MISSING SOMETHING.
Any help would be appriciated.
You are right...the instructions are asking you to do to much! I just removed the belt guard and they went right on. It is a little tight, but it worked fine. I did not have to touch the rear wheel settings.
You can do it if you have a short enough tool to get in there without damaging the belt. \\; I used a GearRachet and a cut-off torx tip. \\; Any similar setup should work.
Hey \\; \\;jcd15
are you interested in getting rid of \\;the stock belt gaurd bracket?(once you get it off that is) \\; effn stealers want $15 and it not a stock item
best wishes
Punty
Hey \\;\\\\\\;\\\\\\\\\\\\\\; \\;\\\\\\;\\ \\\\\\\\\\\\;jcd15
are you interested in getting rid of \\;\\\\\\;\\\\\\\\\\\\\\;the stock belt gaurd bracket?(once you get it off that is) \\;\\\\\\;\\\\\\\\\\\\\\; effn stealers want $15 and it not a stock item
best wishes
Punty
I am on vacation next week when I get back it is yours
Just send me an e-mail to get in touch with you or a pm
You can do it if you have a short enough tool to get in there without damaging the belt. \\;\\\\\\; I used a GearRachet and a cut-off torx tip. \\;\\\\\\; Any similar setup should work.
Thanks icecaps
this is why this site is so great.
