EFI
Old Mar 8, 2006 | 12:35 AM
wayne3724's Avatar
wayne3724
Default EFI
Okay guys, I've heard all the B.S. I got sucked into the Fuelpak based on Vance and Hines reputation. They can have that piece of crap back. Now it's down to a poll on who has had the best luck with what and what will actually fit in an 06 Dyna. If money is no object and you want your scoot to run well and be able to make necessary adjustments, which one. ? Power Commander? Dobeck's TFI? Etc...I just want something that fits and works! I'm running a Doherty Cleaner and Samson Street Sweepers if it makes a difference.
Bring it on!!!
Old Mar 8, 2006 | 12:39 AM
HDF Tech's Avatar
HDF Tech
Default RE: EFI
SERT if you have the $$$ and a dyno to set it up or I like the TFI also, dyno not necessary and they are easy to install and set up. Work well also, more user friendly and less skills to set it up. Also can be removed without a trace for warrantee work and can be reused on other bikes too.
Papa Joe
May 16, 2013 06:51 PM
misfitJason
Feb 1, 2012 01:55 PM
Schaub85
May 15, 2009 05:53 PM
BEAST
Dec 31, 2008 10:05 AM
70mach1
May 8, 2008 12:04 AM
