oil leak
Old Jul 4, 2008 | 11:31 PM
surreyguy's Avatar
surreyguy
Default oil leak
went on an 800 km ride this weekend ,not sure what that is in mph but it was about 13 hours of riding.when i was allmost home i noticed some oil leaking out of the bolt that holds on my air filter.next day i stopped by the hd dealer and asked the service manager about it .he told me not to worry about it ,its a flaw and he has seen a lot of that.not sure if he is&nbsp\\;\\\\\\;correct about that because the bolt is hollow&nbsp\\;\\\\\\; for a reason.my question is&nbsp\\;\\\\\\;does anyone&nbsp\\;\\\\\\;know why this is.
Old Jul 5, 2008 | 01:18 AM
Other Sheep's Avatar
Other Sheep
Default RE: oil leak
The harley motor has breathers for the barrels. They vent into the air cleaner. Under hard use there will be a small amount of oil that will find its way to the air cleaner. If you have a little too much oil in the bike that will find its way to the air cleaner also. Keep the level at the proper fill mark. ALL harley motors will do this. There is nothing wrong with your bike. You can&nbsp\\;quit worrying now.
Old Jul 5, 2008 | 01:34 AM
surreyguy's Avatar
surreyguy
thanks&nbsp\\; for the reply ,thats the responce that i thought i wud get from the service guy.oh well.thanks again
Old Jul 5, 2008 | 08:03 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
What kind of air filter setup do you have?
Old Jul 5, 2008 | 08:10 AM
maddghost's Avatar
maddghost
I noticed that when I removed the cover from my a/c.I,m starting to beleive that it is normal! I have never overfilled the oil however I am known to gun the engine now a nd then!
Old Jul 5, 2008 | 09:07 AM
Varmint's Avatar
Varmint
&nbsp\\;It's not just oil u are seeing .&nbsp\\; It's water MIXED w/ oil.&nbsp\\; And its a good thing*.&nbsp\\; As Crankcase pressure builds up, water vapor mixed with oil
&nbsp\\;is routed from the lower end through a filter/umbrella valve in the top end and then exits into your throttle body&nbsp\\;via breather bolts then tubes.&nbsp\\;
Speaking of which,&nbsp\\;Where are your tubes?&nbsp\\;
&nbsp\\;
*Its a good thing cause if it cant escape through the above mentiond way.
It will find another way out. Most likley through a seal in your crankcase.
&nbsp\\;
&nbsp\\;
Old Jul 5, 2008 | 01:44 PM
surreyguy's Avatar
surreyguy
all good points, it makes sence to me now.not sure why the service guys didnt know that.the air filter i got is the s.e heavy breather kit.
Old Jul 5, 2008 | 08:14 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
&nbsp\\;
&nbsp\\;Do you have the stock air cleaner yet and like some asked where is your vent hose?
Old Jul 5, 2008 | 09:22 PM
surreyguy's Avatar
surreyguy
there is vent holes on the side next to the bolt that holds that air filter on.i do not have the stock air cleaner anymore
Old Jul 5, 2008 | 10:11 PM
up in minot's Avatar
up in minot
Is this what causes the bike to "whistle" from the a/c when I shut her down?
BobRR
Jan 25, 2019 08:32 PM
AMP'd
May 11, 2018 09:50 AM
ricmd
Jun 7, 2010 09:11 PM
Live2Ride
Oct 23, 2007 04:56 PM
hawaiibound
Mar 26, 2007 08:08 AM
