Lame A$$ Service manual
Old Jul 8, 2008 | 12:14 PM
rounder's Avatar
rounder
Default RE: Lame A$$ Service manual
ORIGINAL: BlockHead96
Thanks for the input guys, should have held onto the $64.00 I wasted on the POS manual, that really doesn't tell you how to do anything. If anyone is considering wasting their $$ on that manual, DON'T, Save it for something else. It's about worthless! If anybody else has tips, please chime in!
the harley service manual I have tells me how to do just about everything...It does take into account that the reader has some common sense and mechanical ability.... Like how to loosen a bolt or be able to figure out the right size wrench by trying a couple on the bolt....
Also the manual does not cover accessory modification that is not stock on the bike...sooo...read the instructions that come with the parts you get as well...
True it does not teach mechanical ability... perhaps you need a class....probably can go to a basic class so you can learn a few things at your local vo-tech center...
I am being sincere..
Old Jul 8, 2008 | 12:37 PM
mud's Avatar
mud
ORIGINAL: rounder
Well put rounder.
mud
Old Jul 8, 2008 | 12:54 PM
BlockHead96's Avatar
BlockHead96
Rounder and Mudpuddle, Don't be a Smurf! Gimmie a break. I guess your mentalities are, if HD prints it, they can do no wrong. Why make excuses for HD?? Aren't they capable of knowing how to write a manual??? After all, if you read the book yourself, at the front they claim they may need hep with the manual as they aren't sure themselves they know what their printing! Ahhhh, America in the dumbing down process at work. Hell, they can't tell you what size bolts are on their own bikes&nbsp\\;\\\\\\;and that's a service manual??? LOL&nbsp\\;\\\\\\; As you put it, guess I don't have any common sense, maybe not, after all I did fall into the over hype over price Harley crowd!
&nbsp\\;\\\\\\;
OK, end of rant!
&nbsp\\;\\\\\\;
Thanks guys for the valuable input.
&nbsp\\;\\\\\\;
Now here's where I get flamed LOL!
&nbsp\\;
&nbsp\\;
Ps, When is this freakin site gonna get fixed????????? Must need a manual!
Old Jul 8, 2008 | 01:07 PM
Black Bart's Avatar
Black Bart
Blockhead,
A lot of the specs you're asking for are located in the Parts Manual.&nbsp\\; The bolts you speak of, the ones holding the rear turn signals on, are 5/16-18 x 3-5/8" hex cap style fasteners.&nbsp\\; Provided of course that you don't own a Wide Glide\\; if so, then it becomes a 5/16-18 x 1-3/4" hex cap.&nbsp\\; Hope this helps.
&nbsp\\;
Bart
&nbsp\\;
Old Jul 8, 2008 | 01:19 PM
rounder's Avatar
rounder
Rounder and Mudpuddle, Don't be a Smurf! Gimmie a break. I guess your mentalities are, if HD prints it, they can do no wrong. Why make excuses for HD?? Aren't they capable of knowing how to write a manual??? After all, if you read the book yourself, at the front they claim they may need hep with the manual as they aren't sure themselves they know what their printing! Ahhhh, America in the dumbing down process at work. Hell, they can't tell you what size bolts are on their own bikes \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\;\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ ;and that's a service manual??? LOL \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\;\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\; As you put it, guess I don't have any common sense, maybe not, after all I did fall into the over hype over price Harley crowd!
OK, end of rant!
Blockhead I was being sincere when I wrote what I wrote....The info. you want on bolt sizes....IS in the PARTS manual...
my point is why do you need to know the size bolt ???? you have the bike in front of you ...figure it out....
most all on this site that do their own work have raved about the info contained in the service manual...
they also will tell you not to buy the aftermarket one(clymer I think but am unsure)
If you need to know how to take off your wheels..do your services....tear down the motor...align the bike...torque specs... it's in there!!! So, how are those critical components to wrenching on your bike useless??? They aren't. go back and re-read what you are complaining about and put it into perspective.. you are asking the service manual to be the parts manual as well...not to mention to be a how to on adding aftermarket parts???? it is a service manual, not a parts book or modifications book.
www.easybracket.com for a video on installing their turn signal relocation kit....
Old Jul 8, 2008 | 01:27 PM
kk6pg's Avatar
kk6pg
I dont understand what the big deal is with the size of the bolt anyway.
It is what it is. If its not the same as another bolt, then its obviously different.
If youre having trouble getting it out, the answer was addressed with the first few posts.
Old Jul 8, 2008 | 04:35 PM
toecat2000's Avatar
toecat2000
the one hint i have for anyone removing the turn signal wires is not to clip it at the connector.&nbsp\\; The tool is expensive.&nbsp\\;&nbsp\\; I wish I had clipped it back away from the connector and just soldered the wires.
Old Jul 8, 2008 | 05:07 PM
JRK5892's Avatar
JRK5892
wow the manual is the best thing i have ever bought for the bike... are you really mad it does not tell you the bolt size? dude it is a harley #5 star, 3/4, 1/2, or 7/8 and #25 on the big stuff... HARLEY's are pretty basic
Old Jul 8, 2008 | 05:19 PM
BamaStreetBob's Avatar
BamaStreetBob
ORIGINAL: NewMexRider
Bama,&nbsp\\;\\\\\\; If I remember correctly the manual says "the tool" is required to put the wire back in gotta another tip?&nbsp\\;\\\\\\; I would check the manual but I don't have it with me now.&nbsp\\;\\\\\\;
NM
&nbsp\\;
the clip expands into place.&nbsp\\; If you look into the connector&nbsp\\;you will see the side that needs to be pressed in order for it to slide out.&nbsp\\; Then you just push it back in when your done.&nbsp\\;
Old Jul 8, 2008 | 05:51 PM
BlockHead96
ORIGINAL: Black Bart
Blockhead,
A lot of the specs you're asking for are located in the Parts Manual.&nbsp\\;\\\\\\; The bolts you speak of, the ones holding the rear turn signals on, are 5/16-18 x 3-5/8" hex cap style fasteners.&nbsp\\;\\\\\\; Provided of course that you don't own a Wide Glide\\\\\\; if so, then it becomes a 5/16-18 x 1-3/4" hex cap.&nbsp\\;\\\\\\; Hope this helps.
&nbsp\\;\\\\\\;
Bart
&nbsp\\;\\\\\\;
&nbsp\\;
BB thanks for that info, that's what I'm talking about and the info I need.
