Lame A$$ Service manual
Old Jul 7, 2008 | 07:20 PM
BlockHead96's Avatar
BlockHead96
Default Lame A$$ Service manual
OK, wasted my $$ on the pathetic service manual. As with the owners manual, refers to tables or descriptions that don't exist. I want to relocate rear turn signals. Looks like there is a bolt up under the fender that obviously holds it to the fender rails. It doesn't state what size. Any ideas?? Does anyone have some kind of a procedure to remove these lights?? I' am also adding the harness to turn the turn signals into brake, running, &amp\\; signals. I going to buy the Bike Gear lay down license plate&nbsp\\;and turn signal relocation&nbsp\\;kit, I'm hoping the room inside the license plate kit is enough to house the new harness for the signals. Anyone have experience with any of the above??&nbsp\\;&nbsp\\;
Old Jul 7, 2008 | 07:28 PM
hd_sob's Avatar
hd_sob
Default RE: Lame A$$ Service manual
Dunno about the 08s, but on my 06 I had to unbolt the shocks and let the wheel drop so I could get the damn bolts out.&nbsp\\; Others have just let the air out of the tire, but I don't have a compressor.
Noticing your sig, I did time on both CV-59 and CV-61 back in the 70s &amp\\; 80s.&nbsp\\; I still have the occasional nightmare...
Old Jul 7, 2008 | 07:32 PM
BamaStreetBob's Avatar
BamaStreetBob
you got to take the tail light lense off and unplug both turn indicator harnesses, using a straightened out paper clip release the wires from the harness.&nbsp\\; Then remove the bolt holding the housing on and remove from the bike.&nbsp\\; You may need to lift the bike and lower the rear tire to gain better access.&nbsp\\;
Old Jul 7, 2008 | 10:36 PM
donr101395's Avatar
donr101395
Use a 1/2" wrench to loosen the bolts. The easiest way I've found to get the bolts out after removing the turn signals is to use a cutoff wheel and cut them in half. I couldn't get mine out and didn't feel like removing the shocks.&nbsp\\;
Old Jul 7, 2008 | 11:00 PM
NewMexRider's Avatar
NewMexRider
Gotta love this site, always getting tips.&nbsp\\; Thanks Bama I am gonna have to try and figure out the paper clip thing, I need to replace my signal and was initialy going to clip and solder but will have to rethink this.&nbsp\\;
NM
Old Jul 8, 2008 | 02:22 AM
BlockHead96
Thanks for the input guys, should have held onto the $64.00 I wasted on the POS manual, that really doesn't tell you how to do anything. If anyone is considering wasting their $$ on that manual, DON'T, Save it for something else. It's about worthless! If anybody else has tips, please chime in!
Old Jul 8, 2008 | 06:32 AM
shimmon's Avatar
shimmon
which manual did you get... the maintenance manual???&nbsp\\; if so i think this is one of the best buys for a bike...&nbsp\\; but i just relocated my signals, using hd kit, and did have to fight the bolts.&nbsp\\; i was going to cut them off, but ended up just having my buddy lift up on both sides of the strut and push down with his knees on the wheel.&nbsp\\; then i pressed hard to get the bolt past the wheel.&nbsp\\;
&nbsp\\;
i didnt think of taking air out of the tire but that would make it much easier!!!&nbsp\\; i would do this if i were you.&nbsp\\; well good luck!
Old Jul 8, 2008 | 11:26 AM
BamaStreetBob
the tip of&nbsp\\;a test light works real well for removing the wires also.&nbsp\\; Push in and pull at the same time and they will come free.&nbsp\\;
Old Jul 8, 2008 | 12:00 PM
GREENOHAWK69's Avatar
GREENOHAWK69
ORIGINAL: hd_sob
Dunno about the 08s, but on my 06 I had to unbolt the shocks and let the wheel drop so I could get the damn bolts out.&nbsp\\;\\\\\\; Others have just let the air out of the tire, but I don't have a compressor.
Noticing your sig, I did time on both CV-59 and CV-61 back in the 70s &amp\\;\\\\\\; 80s.&nbsp\\;\\\\\\; I still have the occasional nightmare...
&nbsp\\;
You can buy the car compressor that runs off the car's battery when you plug into the cigarette ligther.&nbsp\\; I use this all of the time to fill up the air in tires for my car, cycles and bicycle.&nbsp\\; Works great and their not expensive.&nbsp\\;
Old Jul 8, 2008 | 12:06 PM
NewMexRider
Bama,&nbsp\\; If I remember correctly the manual says "the tool" is required to put the wire back in gotta another tip?&nbsp\\; I would check the manual but I don't have it with me now.&nbsp\\;
NM
