Front brake ?
You have air in \\;\\\\\\;the system. If your bike was on her side for a bit, air leaked into the line. There is a small amount of air at the top in the reservoir, but hydraulic pressure keeps it from getting into the system. Your bike is designed to stay upright at all times, try to keep it that way ( lol )
Fortunately, it is really easy to bleed your lines.
Youâll need a 3/8 open end wrench, thatâsâ the size of the bleeder valve.
10â of clear tubing
A bottle of DOT 5 brake fuid.
Some rags. \\;\\\\\\;
Now go get a 16 oz. empty clean can readily available for free, in your kitchen garbage can, and add about 2 oz of clean fluid to it. Stick one end of the tubing to the bleeder valve, after removing the dust cap. Easy here, they rip off really easy. Now stick the other end in the can with the fluid, and secure it or clip it to the can so the end wonât come out. If it does, air may leak in again and youâll have more work. \\;\\\\\\;Now remove the lid and rubber membrane from the reservoir on the handlebar.
Donât let any debris, water or anything get in there. If you are working outside, wait till thereâs no wind, or do it in the garage. As a rule of thumb, donât allow the level in the reservoir get below half full. Top it as needed. Keep your brake fluid bottle caped tight at all times, if you kick it by accident, youâll have to stop to go get more, youâll be out $15.00 bucks, and youâll have to clean a mess.
Thatâs your set up. Now for the steps
Pump the brake lever slow ,like when you are braking on wet pavement, a few times, keep the lever depressed.
Open the bleeder valve ½ turn, until you feel the lever giving way, now close the bleeder valve.
Let go of the brake lever.
Repeat these procedures until you see no bubbles coming thru the clear tubing, and then you are done
Youâll feel increased resistance on the lever with every time, if it feels mushy still, you are not done.
If you find it is taking longer than it should, stop. Go get a beer, make yourself a sandwich, then clean the pool, do the lawn etc. Sometimes you have to let the fluid settle a bit before you can continue. I also tap the lines and reservoir a few times with the plastic end of a screwdriver to force some of the recalcitrant bubbles out. Donât mix DOT 5 with DOT 4 etc.
Once you get a hold of it youâll see how remarkably easy it is to do, and youâll feel great.
Cheers,
[IMG]local://upfiles/62526/8E27768BC2324DC5BD5CBCC7015DD442.jpg[/IMG]
Great description.
