front brake
Old Mar 16, 2017 | 10:34 AM
Joe 1948's Avatar
Joe 1948
Stage III
Default front brake
went for a ride yesterday all of sudden NO front brake, brake lever bottomed out . got home shut off bike, Walla front brake works again. Started bike this am brake works fine. HELP what's up with the brake!
thanks Joe
Old Mar 16, 2017 | 10:38 AM
Boomer1143's Avatar
Boomer1143
Year and model would help. Does this bike have ABS?
Old Mar 16, 2017 | 01:59 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Done any work to the brakes recently? Sounds like air in the lines. If it was a total leakout they wouldn't come back.
Old Mar 16, 2017 | 05:32 PM
Joe 1948's Avatar
Joe 1948
Stage III
The bike is a 2000 FLHTC
Old Mar 16, 2017 | 05:51 PM
RANGER73's Avatar
RANGER73
Low fluid in the master cylinder or bad o ring on the plunger in the master cylinder. Rebuild it.
Old Mar 16, 2017 | 06:10 PM
Joe 1948's Avatar
Joe 1948
Stage III
Thank You, for that information, now I know where to look.
Old Mar 16, 2017 | 06:55 PM
mkguitar's Avatar
mkguitar
and Joe this can change with temperature- if you have water in the brake fluid, it will expand and contract with temps and also freeze- the ice can cut or push aside rubber seals ( no pressure on lever) or clog lines ( too much pressure on lever).
as above a master cylinder rebuild is in order, don't be surprised if the calipers need rebuild/reseal
also the brakes lines could be crap
mike
Old Mar 16, 2017 | 07:23 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
won't argue it's certainly a possibility, but there are others. Like worn and cocking pads, sticking caliper piston, etc.
Old Mar 16, 2017 | 07:56 PM
RANGER73's Avatar
RANGER73
The way I understood it his lever went down to the grip.
I'd flush it and go with DOT5 too.
zgunnar48
Apr 30, 2015 07:08 PM
Infrigger
Aug 10, 2011 10:50 PM
thumperhumper
Wheels/Tires
Apr 19, 2009 05:32 AM
kennyross
Mar 5, 2009 07:50 PM
Frankster69
Jul 9, 2008 10:20 PM
