need help with elec. problem
Old Jul 10, 2008 | 06:28 PM
hddave2's Avatar
hddave2
Default need help with elec. problem
went to start&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; my 06 dyna and i have no&nbsp\\;\\\\\\;power going to switch, the lights ,nothing.. so i checked the fuses and the battery but all was fine..i probed the red wire going to the ign.switch and no power..i probed the fuses with the test light and nothing. i assume that the switch has to be on to get the fuses to show power with the test light...im at a lose on what to check..anyone know what it could be...i thought the main red wire that goes to the key switch stayed hot all the time and when you turn the key everything gets power.. is this right..
Old Jul 10, 2008 | 06:33 PM
JRK5892's Avatar
JRK5892
Default RE: need help with elec. problem
when you say you checked your battery what do you mean? did you tighen your terminals down? have you washed it lately in alot of water or been caught in the rain?
Old Jul 10, 2008 | 06:41 PM
hddave2's Avatar
hddave2
i pull the cables off , cleaned them then put back tight.. i haven washed it in a few weeks and i havent road it in about 2 weeks
Old Jul 10, 2008 | 06:43 PM
mud's Avatar
mud
ORIGINAL: hddave2
went to start my 06 dyna and i have no power going to switch, the lights ,nothing.. so i checked the fuses and the battery but all was fine..i probed the red wire going to the ign.switch and no power..i probed the fuses with the test light and nothing. i assume that the switch has to be on to get the fuses to show power with the test light...im at a lose on what to check..anyone know what it could be...i thought the main red wire that goes to the key switch stayed hot all the time and when you turn the key everything gets power.. is this right..
This is from 06.
Maxi fuse hot?? in AND out??
test light each point.
then we ll go from there
mud..........
Old Jul 10, 2008 | 06:54 PM
hddave2's Avatar
hddave2
right side of the orange 40amp. fuse is hot the left side is not..i hope this is what you mean maxifuse
Old Jul 10, 2008 | 06:58 PM
mud's Avatar
mud
ORIGINAL: hddave2
Replace the fuse.
What made it blow??
First pull it out and then re seat it.
check again with lite.
mud
Old Jul 10, 2008 | 07:02 PM
hddave2's Avatar
hddave2
if in fact this is the fuse that is bad, would i only find it at the harley shop or would it be somthing i could get at the local auto parts store...i will go out and unplug it and reseat it and let you know ..
Old Jul 10, 2008 | 07:06 PM
Wireguided's Avatar
Wireguided
you could put a meter across the fuse to check continuity..
Old Jul 10, 2008 | 07:12 PM
mud's Avatar
mud
ORIGINAL: hddave2
pull it out and hold it up to the light.
you ll see then if its blown or good.
I dont know who sells em or not.
Probably any good auto parts.
mud
Old Jul 10, 2008 | 07:14 PM
hddave2's Avatar
hddave2
its the 40am fuse..its broke in the middle..not sure how that happened .. now where to get one..
