exhaust question
Old Jul 14, 2008 | 01:08 PM
stbobshadow's Avatar
stbobshadow
Default exhaust question
I want the vance and hines big radius pipes but the dealer says it will be another $375 for a power commander and another $130 for something elese. heard about something called fuel pack and how easy it was to install. If I installed the fuel pack will that be all i need to install the pipes
Old Jul 14, 2008 | 01:59 PM
JRK5892's Avatar
JRK5892
Default RE: exhaust question
if you get a fuel pack you can order it pre loaded for what you have in the bike, then it is just plug and play! the pipes are real easy to install mine took me 15 min to put on.
Old Jul 14, 2008 | 02:27 PM
stbobshadow
sounds alot better than what the dealer said
Old Jul 14, 2008 | 02:58 PM
armybrat02's Avatar
armybrat02
search around on the net I got my pcIII for $250 and did the install by myself. Its easy just goes in line with the ecu. does the same thing as the fuel pack just a different company. pcIII works great and easy to tune. I have it on my fxd with Vance and Hines big radius 2into1 and SE heavy breather
Old Jul 14, 2008 | 03:07 PM
drtheo's Avatar
drtheo
I have the fuel pak it was a simple install and very good instructions for set up.&nbsp\\; you can get them&nbsp\\; on ebay for around $209
Motosportman's Avatar
Motosportman
Just installed the V&amp\\;H staggered short shots this weekend with a fuel pak easy to install, got allof my stuff via Dennis kirk. www.denniskirk.com&nbsp\\;
&nbsp\\;
Old Jul 14, 2008 | 04:17 PM
fontana1205's Avatar
fontana1205
If you got the extended warranty any after market will void it.
Old Jul 14, 2008 | 04:52 PM
stbobshadow
so install the pipes and then the fuel pack and thats it it all sounds too simple
Old Jul 14, 2008 | 06:31 PM
soup48's Avatar
soup48
If you just want to put on the pipes and don't change the air cleaner to a stage 1 you don't need the power command or the fuelpak. If you do go to the stage 1 and get the power command, you will have to get it dyno tuned for better performance. My brothwer has the pc and had his bike dynoed.
Old Jul 15, 2008 | 11:26 AM
drtheo's Avatar
drtheo
the fuel pak is that simple you jsut have to have the high flow air cleaner.&nbsp\\; no dyno tuning necessary.&nbsp\\; No Pooping on the decel either!!
