Tach Install issue
Old Jul 15, 2008 | 10:33 AM
LeadSlinger0311's Avatar
LeadSlinger0311
Default Tach Install issue
Hooking up a tach on 2007 streetbob . have found you can get a sig from #3 hole on ECM , but just wanted to see if anyone else with an 07 did this the write up was for an 06 , dont see why it wont work but just wanted to check .
&nbsp\\;
Slinger
Old Jul 15, 2008 | 10:45 AM
grandpawmoses's Avatar
grandpawmoses
Default RE: Tach Install issue
I did it on an 08 and it worked.
GPM
&nbsp\\;
Old Jul 15, 2008 | 10:47 AM
JRK5892's Avatar
JRK5892
i did on my 06 i do not see why you would not on a 07, the ECM did not change just the program... should work just fine brother
Old Jul 15, 2008 | 10:49 AM
murphdog's Avatar
murphdog
ECM connector terminal 3 works for&nbsp\\;my '07.
LeadSlinger0311
good deal thats what i thought just wanted to check before i rip into it ,
&nbsp\\;
thansk fellas
&nbsp\\;
Slinger
Old Jul 15, 2008 | 09:17 PM
gman's Avatar
gman
for some strange reason, I couldn't get a signal from the #3 on the ECM on my '06 WG.&nbsp\\; Finally got it from the #3 off of the speedo and it works great.
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
Old Jul 16, 2008 | 11:36 AM
LeadSlinger0311
thanks gman
&nbsp\\;
if i dont get it from there I will try it from the speedo
&nbsp\\;
thanks for the heads up
&nbsp\\;
slinger
Old Jul 16, 2008 | 09:00 PM
ioncat14's Avatar
ioncat14
6th Gear
I got the signal right from the speedo also.&nbsp\\; Everything works great.
&nbsp\\;
07 FXD
Old Jul 17, 2008 | 02:49 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
gman - Tell me a little about the fork brace you show. I like the look and am wondering if you noticed any handling differences with it on. Thanks
Old Jul 17, 2008 | 06:18 AM
Tele00's Avatar
Tele00
I just put a tach on my 08 FXDC . Power was obtained from the Orange and White at the speedo you can get the ground at the same plug on the black and grey. My other wire ( pulse )went to the blue and red down at the Ignition coil plug .
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
