Evo80- Neat looking setup- I really like it. To all- the Screaming Eagle chrome dash will fit all street bobs. It is just plug and play except for the ignition switch which is not that hard to move. You just have to take the one out of the neck and pull the wires off of same. Then you just lengthen them and reroute to the new dash. Put on new crimp connectors and hook up to new switch.
i've decieded to go with the screamin eagle setup. \\; There may be a problem with the ignition switch though. \\; The guy at the dealer said that the switch was a "protected part". \\; He said its only installed on the S.E. dyna and matched to the bikes VIN. \\; I want to double check though, is it that you can't buy it, or is it that you can't buy it to match your exisiting key?
From Harley, to install a 2 5/8" dia mini tach on the handlebar clamp-
67206-04 chrome bracket
67523-04 or 67524-04 tach housing ( one is $20, the other one is $52 MSRP)
68986-04 tach (this one is silver and matches my FXDCI- they also make a black face one that matches your speedometer. About $130 MSRP)
A little over $225 at MSRP. If you get 20% off, it can be under $200 depending on which housing you choose.
I'm thinking about putting this setup on my FXDCI.
