Clunk washer fix
Old Jul 18, 2008 | 11:48 AM
carltex's Avatar
carltex
Default RE: Clunk washer fix
Great, my warranty runs out Tuesday. May have to bite the bullet and take it in.
Old Jul 18, 2008 | 12:18 PM
blkfalc4's Avatar
blkfalc4
I just tourqed mine to 80ft-lb and clunk is gone.
&nbsp\\;
BTW, I heard it was harder than the original and the tourque on it was increased.
Old Jul 18, 2008 | 12:33 PM
davidsdad's Avatar
davidsdad
You do not bend the new washer like the original, you just tourqe 80 ft-lbs
Old Jul 18, 2008 | 12:51 PM
Black Bart's Avatar
Black Bart
Carl,
The ID, OD and thickness of washer number 45727-08 is 1.030"ID, 2.0"OD and 0.62" thick.&nbsp\\; Hope this helps.
&nbsp\\;
Bart&nbsp\\;
Old Jul 18, 2008 | 12:56 PM
Black Bart's Avatar
Black Bart
Carl,
Let's try this again\\; OD is 2.0" ID is 1.030" and thickness is 0.062".&nbsp\\; Sorry about the last post.&nbsp\\; Hope you read this one before you make the washer.
&nbsp\\;
Bart
Old Jul 18, 2008 | 02:23 PM
JRK5892's Avatar
JRK5892
cool now i know not to bend it up just torque to 80ft lbs!
Old Jul 18, 2008 | 03:03 PM
badbs101's Avatar
badbs101
Here's a link to the correct part numbers.&nbsp\\;https://www.hdforums.com/m_2806355/tm.htm\\\\\\; I bought the washer myself and brought it to the local HD dealer and had them install it per service bulletin 1215A.&nbsp\\;\\\\\\; (warranty fix)&nbsp\\;\\\\\\; I would have done it myself but the job called for a 1.5" socket to tighten the nut.&nbsp\\;\\\\\\; I couldn't find anything bigger than 1.25 around the house.
&nbsp\\;\\\\\\;
It pays to buy the washer in advance as they probably won't have it in stock and will probably try to fix it by overtightening the nut.&nbsp\\;\\\\\\; The new washer is a bit thicker and doesn't have a locking tab to bend.
Old Jul 18, 2008 | 03:51 PM
streetbobby's Avatar
streetbobby
I turned the adjuster nut down half a turn, torqued the top nut to 65 LBs and bent the washer.....rides better than when it was new!....and no more clunk!
Old Jul 18, 2008 | 05:17 PM
8541hog's Avatar
8541hog
Dealer says mine is not subject to the problem, but I have the clunk, thanks for the info.&nbsp\\; Have to fix it myself now.
Old Jul 18, 2008 | 05:29 PM
carltex's Avatar
carltex
Thanks Black Bart, will have to whip one out tonight at work and install this weekend. If it doesn't fix it to the shop she goes.
