Torque Spec
Old Jul 18, 2008 | 02:11 PM
DoubleU's Avatar
DoubleU
Default Torque Spec
I'm working&nbsp\\;out of&nbsp\\;town and am away from my manual.&nbsp\\;I'm doing some handlebar adjustments this afternoon and am wondering if the 4 bolts that secure the bars to the risers on the street bob mini apes&nbsp\\;have a torque spec? I'm sure "tight enough" will work, but don't want to have them under spec and start moving on me. Thanks.
&nbsp\\;
Dub&nbsp\\;
Old Jul 18, 2008 | 02:21 PM
JRK5892's Avatar
JRK5892
Default RE: Torque Spec
i just loc tite them and then go tight by hand... when i tighten them I do it in an X like you would changing a tire
Old Jul 18, 2008 | 02:57 PM
DoubleU's Avatar
DoubleU
Blue loc tite?&nbsp\\; Thanks.
Old Jul 18, 2008 | 03:27 PM
BluBob's Avatar
BluBob
With riser bolts finger tight:
&nbsp\\; Install rear clamp bolts finger tight, then install tighten front clamp bolts to 12-18 ft-lbs, then tighten rear to 12-18 ft-lbs. Torque riser bolts to 30-40 ft-lbs. You want the risers to be able to move and find the center of the bar before you tighten them down. This way also lets you adjust so your bars are in line with your trees.
Old Jul 18, 2008 | 09:12 PM
maddghost's Avatar
maddghost
&nbsp\\;Blubob seams to have it nailed for you,or you could check this site if your still not sure&nbsp\\; http://www.nightrider.com/biketech/hdtorquevalues.htm
Old Jul 20, 2008 | 06:34 PM
DoubleU's Avatar
DoubleU
Thanks guys.&nbsp\\;Adjustment done. 350 miles this weekend. No issues.
&nbsp\\;
Dub&nbsp\\;
giangofett
Oct 28, 2017 06:54 AM
Codyyy
Aug 5, 2015 02:42 PM
gjasr1960
General Topics/Tech Tips
May 30, 2015 11:33 PM
ElSupremo
May 22, 2010 11:02 PM
RazorFXDB
Aug 1, 2007 10:05 PM
