not until you put the pipe listed in your sig on (I'm assuming you are running stock pipes now)
Once you do both in and out, you'll want to at the very least do an ECM flash (dealer only), but that won't really match your setup. \\; Best bet is an aftermarket fuel management device and a dyno tune.
Alright cool. FedEx just dropped off the intake and I want to put it on. The pipes are on backorder 'til mid August. So I add a FuelPak or similar when I put on the pipes?
Keep an eye on your plugs, they will tell you if you are lean or rich. \\;I'm new to harleys \\;but on my other bike I tuned for the filters. I've seen holes in pistons from running too lean.
Ya you may need some sort of fuel management with that intake. I know just slip-ons you can get by with nothing but usually a intake makes a bigger change in air flow than slip-ons. Id keep a eye on the plugs.
