Apes on Street Bob
Old Jul 21, 2008 | 05:32 PM
theking53's Avatar
theking53
Stage III
Default Apes on Street Bob
Interested in going higher with my handlebars on my 06 Street Bob.&nbsp\\; Does anyone know how high I can go before I have to change the cables.&nbsp\\; I think the stock mini apes are around 10"... Thanks for the help!
Old Jul 21, 2008 | 06:04 PM
Scoob's Avatar
Scoob
Default RE: Apes on Street Bob
I read on here earlier that 14" was about as high as you could go without changing cables. Even then, the brake line had to be manipulated some. I think that is what I read anyway.
Old Jul 21, 2008 | 06:20 PM
motox285's Avatar
motox285
they are 12 inch apes, so 14 sounds about right before going over on the cable length
Old Jul 21, 2008 | 06:52 PM
BluBob's Avatar
BluBob
Those stock bars are 10.25" rise. You have about 2.5 inches available for height, but the width of the new bars will affect that as well. I went up to 12.5" chubbies with stock cables, but eventually replaced them to give me more adjustment room.
Old Jul 21, 2008 | 08:15 PM
GentlemanBiker's Avatar
GentlemanBiker
If you are going to do 14", you need to re-cable and run a new brake line. If you will be running the wiring inside the bar, you will need either an extension kit, a new switch kit with a longer wiring harness, or a solder gun and a lot of patience. If your are not running internal wiring, you should be able to manage with the existing wiring.
Old Jul 22, 2008 | 10:46 AM
JRK5892's Avatar
JRK5892
i run 14's with 2.5 rise on stock bars, intrenal wire, soldered it all up with ext i made, re bent brake line, re routed cables. all stock
HWill
Mar 31, 2017 05:37 PM
seethesvt
Jun 14, 2013 05:56 AM
jmullins
Oct 12, 2012 10:21 AM
nichiowa
Apr 25, 2011 11:07 AM
Sarge82
Jul 5, 2009 03:06 AM
