dumb question
Old Jul 23, 2008 | 09:11 PM
vjtor3's Avatar
vjtor3
6th Gear
Default dumb question
i just ordered a side mount plate holder that attaches to the rear axle. just want to know if i take the nut off,put on the plate,and replace the nut is there any way i could throw anything out of wack as far as the rear wheel goes.thanks
Old Jul 23, 2008 | 09:50 PM
mud's Avatar
mud
Default RE: dumb question
ORIGINAL: vjtor3
Retorque properly,
and youll be fine.
mud
Old Jul 23, 2008 | 11:17 PM
wtf6316's Avatar
wtf6316
Not if the wheel dosnt move. I would jack it up just enough to where there is slight pressure. You can always make the redneck axle adjuster tool to make sure its the same on both sides. Wire coat hanger and a zip tie.
Old Jul 23, 2008 | 11:40 PM
rayfinseats's Avatar
rayfinseats
The adjuster will hold it in place.
Old Jul 24, 2008 | 04:28 PM
DoubleU's Avatar
DoubleU
Did it about 2 months ago. No issues. Just make sure you torque the nut back down to spec.
Dub
Old Jul 26, 2008 | 07:51 AM
SK8ROD's Avatar
SK8ROD
no problem,, dont over tighten. the back axle is 90 - 105 ft/lbs i usually do mine to 100 ft/lbs
Old Jul 26, 2008 | 06:06 PM
HarleypsychRN's Avatar
HarleypsychRN
Torque to spec and you'll be fine...and t looks 100% better.&nbsp\\;\\\\\\; You can get a mediallion to fill in the 3 holes from the old licence bracket you know.
lmz5150
EVO
Nov 4, 2018 04:45 AM
Mr_Taipan
Oct 19, 2015 12:24 PM
katanaplanet
Jul 19, 2012 02:53 PM
06DEUCE
Dec 22, 2006 06:10 PM
klagair
Apr 28, 2006 12:24 PM
