Hi All
trying to drop the rear wheel out of my Iron but the axle seems to be stuck in there? I removed the nut and loosened the adjusters and pushe dthe wheel forward but the axle doesn't want to come out? I can turn it okay but it wont tap out? Am I just being too gentle with it and need to hit it harder or am I missing something obvious here?
Thnaks
tap it with a rubber mallet, I'm not sure what your axle looks like but sometimes there is a divet in the middle of the axle on the end I put a phillips screwdriver in that and tap it out
I had the same problem with my Dyna the first time I removed it. The anti/seize, grease, or whatever the factory had applied to the axle and it had hardened. I had to beat on it very hard to get it out. So much so that I was concerned that I may have damaged the bearings in the process. On reassembly I used grease and have never had a problem since the first time.
guess the bike is lifted in a jack, if the wheel is in the air, it's weigth is on the axle, so put some wood blocks or car jack under the wheel to releive the pressure
The first time I took the rear wheel off my OL's '04, I beat on the axle so hard, it mushroomed and split. I tried penetrating oil, rotating the wheel, taking weight off the wheel, etc. Nothing helped. I had to have the bike ready the next day, so a new axle, with over-night shipping, cost me a hundred bucks. In '04, Sportsters had a 3/4" rear axle. The only year for that size in the rubber-mount frames. PITA! The local dealer had the wheel bearings in stock, so I pressed new bearings in, too. About a $150 fix, plus my time and aggravation, because the factory can't use 50 cents worth of anti-seize. I cut off the end of the axle and use it in a make-shift wheel-truing stand. I wish I had a pic of the axle, before I cut it. A real horror show.
Lesson learned, when I did my '05, I started applying penetrating oil, liberally, two days prior to removal. MUCH easier.
