Rear wheel removal question
Old Jul 19, 2012 | 12:16 PM
katanaplanet's Avatar
katanaplanet
Default Rear wheel removal question
2008 1200XL.
As I stand behind the bike, the retaining clip is on left side. Shall I remove the right side nut and tap out the axle towards the retaining clip?
Old Jul 19, 2012 | 12:34 PM
IamDiabolical's Avatar
IamDiabolical
i removed my axle to put a side mount plate on, I'm not sure how relevant what side the clip is on id imagine the axle slides in both ways.
the retaining clip is to stop the nut from coming loose so remove the clip and take the nut off of the same side, then pull the axle out from the other side.
(don't forget to jack up your bike)
Old Jul 19, 2012 | 01:13 PM
Scuba10jdl's Avatar
Scuba10jdl
The axle comes out the opposite side as the retaining clip. The nut you are talking about (right side, no clip) is actually welded to the axle. The nut on the left side (with clip) is the removable one.
Old Jul 19, 2012 | 02:53 PM
Von_Zipper's Avatar
Von_Zipper
Depending on what pipes you have there may be some extra work to do.
When you put the axle back use antiseize!
Chef 17
May 25, 2018 08:10 PM
ronyd
Jul 20, 2010 02:05 PM
BadPiggy
Dec 6, 2009 12:43 PM
CGLTD
Mar 30, 2009 10:38 AM
eventiller
Oct 20, 2005 03:58 PM
