Rear Axle Camlock - Troubles
Old Dec 6, 2009 | 09:27 AM
BadPiggy's Avatar
BadPiggy
Default Rear Axle Camlock - Troubles
Guys,
This regards my '09 RG.
I install my rear axle starting from the left side, going to the right.
Axle pops out right side, through the spacer and brake and out the swingarm.
I install my camlock then the nut.
Adjust the axle for tension on the belt.
I use 2 wrenches, one to hold the left side in place, the other to tighten the axle nut.
Here comes the problem...
As I thighten the nut, the camlock under the nut wants to turn clockwise...which causes the camlock to roll to the low side of the lobe...enough that it throws my wheel out of line.
Nothing wrong with the camlock...bike has 1400 miles on it.
Anyone ever noticed this happening?
I've given it some thought...I think if I slide the axle in from the right side and install the camlock, when I tighten the nut it'll turn the camlock clockwise again, but it'll remain on the high side of the lobe then.
I can usually figure this minor BS out, but I'm a bit baffled by this.
Any input from you guys???
Thanks!
EDIT: NO...I'm not installing the camlock backwards.
Old Dec 6, 2009 | 10:13 AM
Feedsack's Avatar
Feedsack
Do you have a wrench on the left side the side where your left leg would be holding that nut tight?
Old Dec 6, 2009 | 10:20 AM
nocarb's Avatar
nocarb
Originally Posted by BadPiggy
Guys,
Thanks!
Try sanding back of nut with some emery cloth and a little dab of grease between cam and nut.
Old Dec 6, 2009 | 10:22 AM
BadPiggy's Avatar
BadPiggy
Yes'r.
Use 2 wrenches when I do rear wheels.
A 36mm on one side, Crescent on the other.
After I tighten it, the camlock is away from that tab by maybe 1/8" of an inch, if that much.
Just enough to throw the wheel off and cause the rotor to be cocked in the caliper.
It's like the removable camlock isn't a tight fit on the axle...too much play.
Old Dec 6, 2009 | 10:24 AM
BadPiggy's Avatar
BadPiggy
Didn't think about grease.
I may try this.
If I don't get it figured out, I'm going to install the axle from the right side and see how this works.
Old Dec 6, 2009 | 11:47 AM
BugBYter's Avatar
BugBYter
Per my '05 manual...... "apply a thin film of anti-seize lubricant to the inboard side of the cone nut....". That allows the nut to turn and not take the cam with it. At least in theory. The grease already mentioned should do the same thing.
Old Dec 6, 2009 | 12:43 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Definitely use Anti-seize on the back of the bolt...........problem solved.
skyguy59's Avatar
skyguy59
6th Gear
Clean the back side of the nut and the front side of the cam and put a little dab of grease or antisieze on the nut. Another thing that is helpful make the last turn of the axle in the direction that tightens the belt. This takes the slack out of the the opposite side cam and it wont move when you tighten the nut ( as long as you hold the axle).
I've been doing it that way for 81000 miles and it seems to work.
hdfatbob12
Jan 3, 2024 10:52 PM
Red Dragons
May 19, 2014 09:10 PM
katanaplanet
Jul 19, 2012 02:53 PM
cpsychoholic
Mar 15, 2009 05:14 PM
wadejesu
Feb 22, 2007 07:04 AM
